Question about LG WM2016C
I have had my LG WM2016CW for just over two years. For several months the hot water hose would "squeal" while in use like there was air in the line. I have tightened it more and more and now I have water leaking out of the bottom of the washer that appears to be dripping from the hot water connection inside the washer. I'm assuming the connector or hose needs to be replaced. I didn't buy extended coverage for warrenty, is there still some type of manufactures warranty that would cover this? Is this an easy repair that I can do myself and not void anything? Do I need to call a repair person to fix it?
catriver
  • 878 Answers
SOURCE: LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Posted on Aug 14, 2006
onthejob5130
  • 640 Answers
SOURCE: LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Posted on Dec 25, 2008
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 15 Answers
SOURCE: Water filter at inlet hose on LG WM2016CW
Why not try to clean these with a little CLR lime and rust remover and see if that does the trick....
Posted on Sep 06, 2009
omaharox
  • 166 Answers
SOURCE: LG Washer leaking water underneath
Some times a water valve can have a leak inside the machine coming out the bottom.
Also make sure the filter in the front lower left corner is tight in the housing.
Tub inside could be damaged from shipping.
Sears should be able to fix you up.
Posted on Jan 20, 2010
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
Our WM2016CW machine's drain hose has a wire mesh filter on the end of it. The drain hose then is attached to a drain pipe which used to be connected to an old sink (no longer there). Is this mesh
This is not needed, It has been put in place maybe because of a tendency to get blockages in your drains? These machines break up the particles a lot to assist in removing them and resulting in less pump blockages so what used to collect in older machines pumps now goes down the drain.
Mar 05, 2012 | LG WM2016C
I cant find a part number or part for the water inlet filter on a LG WM2016CW washing machine
The part numbers are
COLD WATER VALVE 5221ER1003C
HOT WATER VALVE 5220FR2006L
Your local appliance parts store may have them available or they are defeiently availavle at;
searspartsdirect.com
repairclinic.com
apdepot.com
partselect.com
apwagner.com
GENE
Sep 17, 2011 | LG WM2016C
LG Model WM2016CW Front load washer is 1 year old. It quit today. No power---NOTHING happens. Any answers??
Same thing happened to me
I freaked out
Then I emptied the water basin, on the front of the machine near the bottom. then it started up and worked
Feb 22, 2010 | LG Washing Machines
IE error code
IE. is inlet water valve error.
Make sure someone did not turn off the water to the washer!!!!
Remove fill hoses and check filter screens on washer and fill hoses and clean if needed.
If problem continues water valve may need to be replaced.
Jan 16, 2010 | LG Washing Machines
Squeals when hot water inputs
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 10, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Following a 1E error I found the gaskets in both supply hoses had perished and the debris had blocked the mesh inlet filters, causing the grinding noise that the pump makes when it can't get water. The original LG filters are indeed removable, in bits. Their little plastic tag for pulling them out snaps off so you end up digging the filter out, just be careful 'cos there's another mesh behind the filter on the hot and there's a rubber seal behind the cold one. Easiest thing is to forget replacing them with original parts and get the old fashioned kind from Lowes etc, $2 for a 3 pack, these fit into the end of the supply hose and are a rubber gasket with mesh in the middle so you won't even need to buy gaskets to replace the ones that fell apart.
Sep 06, 2009 | LG WM2016C
LG Tromm Not Dispensing Bleach
My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
Nov 24, 2008 | LG WM-2277HW Front Load Washer
LG WM2016CW front load washer
Check to make sure that the filters in the water valves are not clogged up.  Go behind the machine, turn off the water supply and disconnect the hoses on the machine side.  Look inside the water valves and check the filter screens to make sure they're clean.  Get a large bucket and open the water valve to clear out the hoses and make sure you have good water flow coming out of the hoses.  If both of those situations are cleared up, your machine should work properly.
Aug 07, 2008 | LG WM-2077C Front Load Washer
Bleach dispener always full of water
call for service, they will probably order the dispenser assembly (includes new drawer.)
Apr 23, 2008 | LG WM2455 Front Load Washer
LG WM2016C Logo
55 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
