Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
OK, I'm getting error code E1 then flash to 76. And this means what and what should I do now? I want a bath please :D
5 Suggested Answers
SOURCE: I have a Rheem tanklees water heater, model
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Posted on Nov 09, 2010
  • 3 Answers
SOURCE: I AM GETTING AN ERROR CODE OF C7 76 ON THE REMOTE
means that your remote panel is no good. remove cover and disconect the 2 wires. put cover back on and plug in. if that gives you hot water call the company and tell them you have a code76. they will send you a new panel for free over night
Posted on Feb 22, 2011
SOURCE: I am getting the c7
Error code 76 has to do with communication fault with remote
Error codes here: http://www.palomastore.com/paloma_error_codes.html
Posted on Mar 01, 2011
SOURCE: We have enjoyed a Rheem Thermostat and a Paloma
Before calling service technician, open following links for Rheem troubleshooting resources, including generic error codes and contact information for Rheem and recent manuals:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://www.fixya.com/tags/rtg_74pvn
Error codes are start place for troubleshoot, and multiple error codes can indicate bad PC board.
Same error code on one machine can be different cause and solution than another machine.
Error 76 is usually communication problem with remote control.
Disconnect wires from machine, and clean terminals is a start point.
Wire between machine and remote might be bad, or remote control is bad, or PC board or wiring connections are bad.
The problem might be solved by having technician catch the machine up on yearly maintenance.
Manual for same-similar product shows maintenance and troubleshooting and a few error codes, but not 76:
For the most part, the manual recommends calling service technician instead of offering DIY details.
http://waterheatertimer.org/pdf/DirectVentManualRTG-74PVN-1.pdf
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jun 09, 2011
I have Model PTG2-42PVN it shuts off and the remote flashes C7 and 76. What does this mean???
Could be the remote control. Disconnect remote and see if tankless works fine.
Probably bad PC board. Rheem will send new board and you can install yourself.
Bad PC board is kind of like the motherboard on your computer, so expect same level of performance after replacing motherboard ... which usually means the computer's days are numbered before another major problem.
Copy following links:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Sep 18, 2012 | Water Heaters
Have a Rheem PTG-74PVP tankless water heater. Shuts off after a few minutes while taking a shower. Get a code 76 C8
Before calling service technician, open following links for troubleshoot resources including error codes and rheem chat, and typical scheduled maintenance:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Error 76 can mean communication failure between tankless and remote control, which can include bad remote control, bad wire, bad wiring connector, or PC board failure.
Disconnect remote control and see if tankless will work.
Error C8 76 can mean PC board failure.
Contact Rheem and/or service technician.
Take a moment and rate answer:
Sep 07, 2011 | Rheem Tankless Hot Water Heater...
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
http://waterheatertimer.org/pdf/Error-code-13.pdf
Aug 12, 2011 | Rheem RTG-66DVN Direct Vent Natural Gas
Remote is flashing C8 and 76, alternating. I turn the unit off, then back on, and I get hot water for about 10 seconds, then it goes cold and the same error message occurs. Unit is Rheem Main Remote...
Before calling service technician, open following links for Rheem tankless resources including error codes and Rheem chat.
Disconnect wires from remote to see if system stabilizes. Unit will heat to default temperature without remote.
76 can mean communication failure with remote control
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Jul 31, 2011 | Rheem Tankless Water Heater Main Remote...
Getting a 76 flashing on my Paloma PTG-74XP tankless water heater
Error code 76
http://waterheatertimer.org/pdf/Rheem-Tankless-Fault-codes.pdf
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Mar 30, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
FLASHING CODE C-7 WILL WORK FOR A WHILE THEN STOPS
disconnect the remote and see if the unit works properly; could be lost comm. between the burner control module and the burner assembly.
If your getting error code 76; contact Rheem customer support at (800-432-8373) and notify them IF you are getting a code "76" error
Mike...
Nov 15, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
C4 76
76 is a bad connection between the controller and the unit. try unplugging the controller and running it, also check the wiring between the two units. if that is not it. it means that one of the control boards it shot
Jul 18, 2009 | Water Heaters
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
73 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
