Question about HP Deskjet D4160 InkJet Photo Printer
Colored print is not in good quality,there's a line in every color
    Master:
  • 473 Answers
Issue with Cardtrige overflow need to be clean and re calibrate ..
Posted on Oct 01, 2010
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    When I print a color page, there is a multi colored line about a 1/2 inch thick along the left side of the paper. The print quality is good for everything on the page, just this line of swirled colors. ...
    Run the Print Quality test. Sounds like one of the color cartridges is bad.
    Also run the Disable Cartridge test. That will let you test each cartridge by itself.
    Before you do that, open the front door halfway. Now you can see each of the color drums in each cartridge. One of them may have a 1/2" stripe on the drum on the left side.
    Nov 29, 2010 | HP Color LaserJet 3500 Printer
    Toubleshooting and routine maintainance is what comes oout on myscreen
    Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
    http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
    How to improve print quality Cleaning the print head
    To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
    Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
    Caution
    Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
    1 Press Ink.
    2 Press or to select Cleaning.
    Press Menu/Set.
    3 Press or to select Black, Color or All.
    Press Menu/Set.
    The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
    Checking the print quality
    If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
    1 Press Ink.
    2 Press or to select Test Print.
    Press Menu/Set.
    3 Press or to select Print Quality.
    Press Menu/Set.
    4 Press Color Start.
    The MFC begins printing the Print Quality Check Sheet.
    5 Check the sheet to see if the quality is OK by following these steps:
    Color block quality check
    The LCD shows:
    6 Check the quality of the four color blocks on the sheet.
    7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
    OR
    If you can see missing short lines as shown below, press 2 (No).
    The LCD will ask you if the print quality is OK for black and three colors.
    OK Poor
    Is Quality OK?
    1.Yes 2.No
    Black OK?
    1.Yes 2.N
    8 Press 2 (No) for Black or three colors
    with a problem.
    The LCD shows:
    Press 1 (Yes). The MFC will start cleaning the print head.
    9 After cleaning is finished, press Color Start. The MFC will start
    printing the Print Quality Check Sheet again and then return to
    step 5.
    10 Press Stop/Exit.
    Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
    Cannot print keeps saying clean printer cannot find info to do it
    Caution
    1 Press Ink.
    Press Menu/Set.
    Press Menu/Set.
    1 Press Ink.
    Press Menu/Set.
    Press Menu/Set.
    The LCD shows:
    OR
    OK Poor
    Is Quality OK?
    1.Yes 2.No
    Black OK?
    1.Yes 2.N
    with a problem.
    The LCD shows:
    step 5.
    10 Press Stop/Exit.
    There is more, but too long to put here.
    Jan 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
    A faint line shows up down the middle of the page, when printing a photo
    from cnet review of the product
    • Unfortunately, as with the Z1420, fast print speeds come at the cost of print quality with the Z1300. Black text prints, though nicely dark, were beset by obvious jaggedness. The color graphics print had a slightly faded look to it and color blocks showed graininess and faint horizontal striations. Barcode-style patterns were muddled, too. For our tests, we printed color 4x6 photos with the standard black and tricolor cartridges, as Lexmark did not include photo ink tanks with the test unit. The colors were dull, details were hazy, and again, the entire print was marred by graininess and faint horizontal lines. That said, nobody buys a $25 printer to print photos for framing or to create displays for a classroom science project. A $25 printer is a convenience item for occasional reference prints, and as such, the Z1300 does its job.
    Inkjet printer quality
    (Longer bars indicate better performance)
    b.gif Photo b.gif Graphics b.gif Text Canon Pixma iP1800
    Good Good Good Lexmark Z1300
    Fair Fair Fair Lexmark Z1420
    Fair Fair Fair
    Sep 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
    My copy prints come out blurry after changing ink cartiges
    Try this:
    Checking the print quality:
    1. Press the Ink or Ink Management key on the control panel.
    2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
    3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
    4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
    5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
    6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
      If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
      If you can see missing short lines, press 2 (NO) and go to Step 7.
    7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    8. The display will then show START CLEANING? 1.YES 2. NO.
      Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
    9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
    10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
    Setting the Alignment:
    3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
    4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
    5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
    6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
      If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
    7. Press Stop/Exit.
      If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
      Thanks, Joe
    Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
    Problem with printing smoothly
    Hi morshi. I found a potential solution to your problem with your 5610 printing vertical lines at HP.com:
    Vertical black lines or streaks
    It's hard to tell from the rest of your message what other problems you're describing. I did find a troubleshooting page at HP that shows how to address general print quality problems:
    Problem with quality of copies
    If those links don't solve all of your problems, the Color printing issues page for the 5610 at HP has numerous other solutions:
    I know the name of that last link may seem misleading since you haven't described color printing issues, but the links on that page offer different general print problems and their solutions.
    Good luck.
    Sep 30, 2008 | HP Officejet 5610 All-In-One InkJet...
    After replacing the ink cartridges ran out I replaced them for new ones and the machine is not telling me that cartridges are empty tried and tried to rereplace them and I still keep getting the same
    1. Press the Menu/Set key.
    2. Press the up or down navigation key until TEST PRINT appears on the LCD.
    3. Press Fax Start. The DCP/MFC begins printing the Print Quality Test Sheet.
    4. By reviewing this Test Sheet, you can determine if the print quality or alignment needs improvement or adjustment.
    StepA - Checking the print quality:
    1. The display will read "IS STEP "A" OK?" 1.YES 2. NO.
      Before choosing YES or NO, closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
      If all lines are clear and visible, press 1 (YES) and proceed to StepB. If you can see missing short lines, press 2 (NO).
    2. The display will then ask you if the print quality is OK for each color. Press 2(NO) for any color with the problem.
    3. The display will then show START CLEANING? 1.YES 2. NO.
      Press 1(YES) and the DCP/MFC will start cleaning the color ink cartridges.
    4. After the cleaning is finished, press Fax Start. The DCP/MFC will print another Print Quality Test Sheet.
    5. If you can see missing short lines in any of the four color blocks press 2 (NO) and repea the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
    StepB - Setting the Alignment:
    1. The display will then read "IS STEP "B" OK?".
    2. Examine the 600 DPI and 1200 DPI test prints on the Print Quality Test Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1(YES).
    3. Print another Print Quality Test Sheet by following the steps provided at the top of this page and check it.
    4. Press Stop/Exit.
    Aug 11, 2008 | Brother MFC 420CN All-In-One InkJet...
    HP Deskjet D4160 InkJet Photo Printer Logo
    Seeker5211
    Seeker5211
