Question about Panasonic Audio Players & Recorders
SL-MC410 checking discs on start up and then won't stop. Cannot turn off.
  • 3 Answers
As posted here, it seems to be a software falure or so, but is only a transmission belt that went loose over the years
Tech SL MC410 Continously displays Checking Disc
Posted on Oct 22, 2015
NEED A BELT FOR TECHNICS DISC CHANGER MODEL NUMBER SL-MC400
take the belt to your local ace hardware and look for an o-ring that is slightly smaller than the stretched out belt. this will work just as well.
Mar 01, 2015 | Technics SL-MC400 110-Disc CD Changer
Technics sl mc410
The Optical Pickup(laser) has worn out. When you place a disc in the drawer, it has to load and read the TOC(table of contacts) if if can't read that, it assumes there is no CD in the drawer and stops or ejects.
Aug 28, 2014 | Technics Audio Players & Recorders
Tech SL-MC410. Continously displays "Checking Disc"
When the unit is saying "Checking discs" and neither goes further nor turns off (just says "Off" but doesn't), the reason is still the main belt (accessible from the top as soon as you lift the cover) that is too loose. When the belt is way too loose, the unit doesn't move at all, if the belt is little too loose, the player-unit will move a bit, but there is not enough torque on the gears to reach the end position (where the player unit is secured against movements).
May 07, 2012 | Technics SL-MC400 110-Disc CD Changer
1992 saturn sl engine won't turn over
Best case scenario: Your battery is dead or almost dead.Worst case: The engine has seized and you have to replace it. Do the dash and interior lights stay on or turn out when you try to start the car?
Apr 19, 2012 | 1992 Saturn SL
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
2002 saturn sl won't start, turn over but won't start
If the engine fires up for a second or two with starting fluid then the fuel pump is weak.I would check the fuel pressure and if its not within the specs then replace the pump and filter.
Jan 26, 2012 | 2002 Saturn Sl
I was driving and the car cut off. It won't start but it cranks and won't turn over.It is a 1995 Olds Cutlass Ciera SL, 6 Cylinder.
your terminology is wrong.if it cranks its turning over what you mean is it won`t start(fire up) as you said at the beginning.anyways it sounds like you could have a fuel pump problem that stop working.this happens alot.you should check for spark at the plugs to make sure its not an ignition problem.did you notice a check engine light on when it was running.if so there will be a code in the ecm and may be the cause of your problem.
Jul 17, 2011 | 1995 Oldsmobile Cutlass Ciera
277 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
