Question about Samsung HLN617W 61" Rear Projection HDTV
I have a Samsung HLN617W DLP tv and it makes a buzzing/humming noise when turned on, it will get a little lower as time passes but it will never go away. the noise will stay in the background and you can hear it if you mute the set. the noise will go away the minute it is turned off. however the picture quality is still great and so is the sound..
  • Samsung Master
  • 5,138 Answers
Bad Color Wheel. Encompass Parts Distribution 1-800-638-3328
Samsung Parts.com 1-800-627-4368
PN# BP96-00250A Price $82.66
Posted on Oct 01, 2010
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Samsung dlp tv makes loud noise when turned on. Previously it was turning itself off.
Bad Color Wheel, Located Right Behind Lamp when you remove Lamp you will see the Color Wheel.
Oct 03, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Buzzing sound on samsung
it sounds that u have a color wheel problem my friend
Jan 19, 2010 | Samsung DLP HL-P5663W 56" TV
My samsung dlp has a loud buzz/hum noise when it comes on and them remains though somewhat less loud
The buzz can be the color wheel or one of the cooling fans going bad. The only other thing that could cause a buzz would be the ballast going bad. Call a local repair shop to further diagnose the problem
Dec 28, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLN617W TV does not turn on, all 3 lights flash
In this case it seems you may have an issue with your ballast. Either it's going out or barely starting. I recommend you replace it
Aug 06, 2009 | Samsung Televison & Video
Buzzing noise
You need a new color wheel.  Partstore.com is a good place to get them.
Check out:  http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jun 17, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
660 people viewed this question
Henry  Thomas
Henry Thomas
