Question about Kyocera Mita FS 1000+N Laser Printer
Error Code explanation for Kyocera FS1700+
Model 1700+ not in your list so used FS-1000+N ( same age )
After power failure at first boot the printer reports E2:0207660 Call Service Personel.
Switch off and reboot runs O.K. but too much toner ?
What does E2:0207660 indicate ?
ibssinternatioanl@yahoo.com
  • Anonymous Apr 09, 2009
    callservice person e2 052278
L e d are villings countineve one by one up to down
Posted on Jun 14, 2008
Kyocera 1020 error codes list
Hi Pandirayaj,
I have this manual for you to see errors in Kyocera FS-1020D. Hope it helps.
Kyocera FS FS 1020D Operation Manual Page 37 Error Messages
Apr 25, 2014 | Kyocera Mita FS-1020D Laser Printer
Error c3200
C3200 is an exposure lamp problem. The simplest explanation would be a bad exposure lamp or inverter. More exotic, but still possible, is very cold environment, dirty AC power, a bad CCD, or a bad main PCB.
Jan 29, 2013 | Kyocera FS-1118MFP Laser Printer
Error code E2 0012223
Laser scanner motor error. The polygon motor does not deliver a synchronous output (L) within the predetermined period of time. The scanner unit may need cleaning. be careful as there is a laser working in this area turn all power off before attemting. The laser unit sits under the top cover.
May 06, 2011 | Kyocera Mita FS 1700 Laser Printer
Kyocera FS-2000D This printer comes up with error code 6120-0044336 at power on Is this a fuser error?
Yes it is a fuser error.
6120 Abnormally high fuser thermistor S temperature
*35/37 and 45/47 ppm printers (EUR/USA model) only
The temperature of the fuser thermistor S detects 250°C/482°F or more continuously for 3 s.
Shorted fuser thermistor S.
1. Measure the resistance. If it is 0 ω, replace the fuser thermistor S.
2. Defective engine PWB.
Replace the engine PWB
Mar 08, 2011 | Kyocera FS-2000D Laser Printer
Kyocera fs 1016 mpf printer error service call 6400
Code: 6400
Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB
- Defective the engine/high voltage PWB.
Dec 15, 2010 | Kyocera FS-1016 Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Kyocera mita fs 1000+ error pages
install the generic postscript driver and go here to tune it http://localhost:631
Jun 09, 2009 | Kyocera Mita FS 1000 Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera Mita FS 1000+N Laser Printer Logo
455 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
