Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper jam hello, i have the following error message on my printer paper output slot the paper is jammed. clear the paper and press ok. there is no paper jammed anywhere in the printer. i have turned it off, unplugged it and plugged it back in and still have the same error message. how do i fix this?
  • Guest2U May 27, 2008
    Same Problem E 3 error message which translates to Paper Jam. NOW- my wife did pull the stack of paper when she realized that she what she had printed out was 58 pages of nonsense. But there was no jam- and can't find anything physically wrong- and no way to reset the thing. It has printed less than 100 pages in its lifetime- Only have replaced one of the original ink tanks. It is OUT of warranty but there should be plenty life left in this thing.
  • Phil1971 May 28, 2008
    same problem here - no paper any where but gives an e3 error message.
    Happened a few times now and the only way Ive got if working is by shaking the printers upside a bit (very techinical I know). That doesnt seem to be working now.
    I use this for business and am thinking of replacing it after just 1 months use
I had exactly the same problem - kept flashing E 3 but no paper in the $%%ing thing. I did all of the above and still wasn't able to reset the printer - absolutey ridiculous design. I ended up chucking it out of the kitchen window, and buying a different printer. I can recommend this.
ADAM
Posted on Jun 24, 2008
The reset instructions didn't work for me either. I can get it into the service mode, but it doesn't seem to respond to anything from there. Thanks for the try- I do appreciate it!
Posted on May 29, 2008
The shaking thing does work from time to time but I dont think I like doing it often (I have it working again now).
Ive tried those reset instrcutions and they dont do anything - now I may be following them wrong as they are quite easy to mis interpret.
It does seem like a small problem being turned into a real pain with what otherwise is quite a good combo printer.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
Try this
Open up the printer as much as possible and turn it upside down and shake it (be careful with the scanner lid though). See if anything falls out
or this service mode
  • Turn off the printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for three times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Posted on May 29, 2008
    My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
    The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
    If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
    The following is for the MP600:
    Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
    Solution: Removing paper jams MP600
    Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
    Clearing paper jams inside the printer
    Clearing credit card-sized or 4" x 6" paper jammed inside the printer
    ASF / Paper Output Slot
    1. Turn off the printer.
    2. Remove paper from the ASF.
    3. Gently pull the jammed paper out.
      1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
      2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
        The above illustration shows a PIXMA MP500.
    4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
      Note:
      Be careful not to touch the components inside the printer.
    5. Turn on the printer and confirm that the Alarm light is off.
      (If the jammed paper remains in the printer, the paper may be automatically ejected.)
    6. Load paper back into the ASF.
    7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
    Top
    Paper jams inside the printer
    1. Turn off the printer and disconnect the power cord and USB cable.
    2. Remove the jammed paper slowly using the following procedure.
      1. Open the rear cover to check if the paper is jammed.
      2. Pull out the cassette and check if the paper is jammed inside the cassette area.
      3. Stand the printer with the left side down, holding the document cover.
      4. Press the tabs together and pull the green cover toward you.
      5. Check if the paper is jammed.
        (If you were not doing Duplex printing, you do not have to follow this procedure.)
      6. Close the green cover and place the printer back to a normal position.
    3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
    4. Load paper back into the ASF or cassette.
    5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
    Top
    Clearing credit card-sized paper jammed inside the printer
    Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
    If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
    2. Load the same paper type that is jammed inside the printer in portrait orientation.
    3. Power on the printer.
      The paper stock in the ASF will automatically feed the jammed paper from the printer.
    4. To resume printing, load the paper in portrait orientation.
    If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
    2. Open the rear cover.
    3. Fold in four a piece of letter-sized plain paper.
    4. Push in the folded paper until it hits the jammed paper.
    5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
    6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
    7. Pull out the folded paper and close the rear cover.
    8. Power on the printer and confirm that the Alarm light is off.
      The jammed paper should automatically eject.
    9. To resume printing, load the paper in portrait orientation.
    Trust this is helpful.
    Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
    I have the following error message:
    SOMETHING MOST LIKELY FELL DOWN IN BACK PAPER PATH OR TORN PAPER THAT HAS PAPER SENSOR STUCK. HARD TO SEE SOMETIMES. MIGHT WHAT TO TURN MACH UPSIDE DOWN AND SHAKE BE VERY CAREFULL
    Apr 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
    Error paper output slot. the paper is jammed clear
    Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
    Ash
    Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
    Paper Output Slot Error Message
    When the print head temperature falls, the error is
    automatically cleared.
    Note:
    If the print head temperature exceeds the specified limit
    when the scanning unit (printer cover) is opened, the
    carriage does not move to the ink tank replacement
    position.
    Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Canon error code 6000 in mx308
    please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
    Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
    5110 ERROR ON PIXMA PRO 9000
    Solution: Press ON/OFF switch to reset the multifunction device
    Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
    1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
      Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
    2. Wait approximately ten seconds and then press the <ON/OFF> button again.
    3. Wait until the device has completed its cycling process before submitting another job request.
    Solution: Removing paper jams MP800R / MP830 / MP530
    1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
      Note: Be careful not to touch the components inside the printer.
    2. Turn on the printer and confirm that the Alarm light is off.
    3. Load paper back into the ASF.
    4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
    Top
    3. Open the rear cover to check if the paper is jammed.
    4. Pull out the cassette and check if the paper is jammed inside the cassette area.
    5. Stand the printer with the rear side down, holding the document cover.
    6. Press the tabs together and pull the green cover toward you.
    7. Check if the paper is jammed.
    8. Close the green cover and place the printer back to a normal position.
    9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
    10. Load paper back into the ASF or cassette.
    11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
    Top
    Thanks
    Thiru
    Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Canon MP610 - Paper jam error message
    PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
    GOOD LUCK
    Jan 04, 2009 | Canon MP610 Photo All-In-One Printer
    Mp830 shows paper output slot jam
    I cannot receive faxes or print anything.
    The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
    Jun 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Canon PIXMA MP150 All-In-One InkJet Printer Logo
    56 people viewed this question
    old marine
    old marine
