I am having static problems. - Audio Players & Recorders
  • boblou1014 May 29, 2008
    I have an RCA #RS2640 radio and CD player. When playing the radio, I get so much static. We live in a two story apartment building. I trying to listen to a Canadian station located approximately 90 miles away. We have an indoor antena but it doesn't seem to help.
    No. I do not understand what you mean by a hard reset to the device.
    Genius:
  • 1,142 Answers
Did you try doing a hard reset to the device
Posted on May 29, 2008
  • Maanita Chadha
    Maanita Chadha May 29, 2008
    You need to check the antenna wiring which might have a cut or it broken cable which is not doing its work as its not holding the proper reception
  • Maanita Chadha
    Check the electrical earth as well as earthing may cause static too
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
Instaalling new ram avoiding static problems.
one way to avoid static, is to literally work naked, on a hard floor (avoid carpets), and allways hold a hand on the frame of the case. but, you realy don't need to work naked either, just make sure that you are properly grounded, (hold on to the frame to decharge yourself of static) work without socks, and preferably on wooden floors or similar. Have fun.
May 14, 2010 | Gateway 310 S PC Desktop
Static problem
Try using a headset or lower the volume.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Apr 11, 2009 | A4tech Viewcam PK335 Webcam
Static humming from speakers
I've had the same problem and I think I've solved the problem. I noticed that they were fine when I first turned them on. After a awhile the blue light would flicker and static would start. I figured there might be some connection so I unplugged my speakers, took off the thin rubber from bottom and removed the 3 small screws. I carefully pulled the circuit board down, spotted the led light and snipped it off. I put everything back together, double stick taped the rubber piece back on, plugged it back in and have been listening static free for hours. Yippee, no more room full of screaming babies (that's what static sounds like to me)! By the way, I'm no expert. I just have a very strong aversion to static.
Good luck,
Beth
Mar 14, 2009 | Insignia 2.1 Speaker System (3-Piece)
Static in between video
Second reason is, if you are using a laptop and have and have added an external microphone between the two it will cause distortion and static.
Jan 02, 2009 | Logitech QuickCam Communicate STX Personal...
Intermittent static in webcam recordings
Nov 02, 2008 | Labtec Webcam Pro
Static on line
Does the static stay on the line after the called party answers?Is the static on incoming and outgoing calls on any phone?if the answer is yes to the above questions,check your house jacks for corrosion.There are a number of things that can cause static inside your house and outside.From the interface box on your house where the wires come from a pole or from under ground is phone company problem.From the box into the house is your problem,so the easy solution is to make the phone company come out and determine from what side the static is coming from.There is usually no charge for this unless you have them come into your house if the problem is there.
tk46
Jul 20, 2008 | Panasonic KX-TG1033S Cordless Phone
Bad Static on the Audio
May 16, 2008 | Logitech QuickCam 961464-0403 Webcam
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
24 people viewed this question
 Grubhead
Grubhead
