Question about LG DLG5932W Gas Dryer
I have a front control gas dryer dlgx8388nm how do i remove the front panal
I need to replace the gas valve.
  • Richard Lew May 11, 2010
    Why do you need to replace the gas valve??  How do you know the gas valve is the problem??
Replace controle panale on 42vp50fw
Are you trying to remove gas control valve?
Open following link to identify specific gas control anddownload possible service manuals for that specific product.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Dec 09, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
My dryer timer does not function properly on auto sense and heats up sporadically. It will dry but takes hours to dry one load of shirts. One time I opened the dryer and smelled gas inside the drum. Ideas...
Sounds like your gas valve coils are your culprit. They are one of the only components inside a gas dryer that can be intermittent.
Here's some step by step replacement instructions:
You will need to remove your lint screen first.
Now remove the two phillips head screws located at the lint screen inlet.
Next while standing in front of the dryer place a hand on the back of the control panel and pull the panel towards you. The entire top of the dryer should slide forward slightly and as it does use your fingertips to lift the top on the side you are pulling on at the front of the top where it meets the front panel. Now switch to the other side and repeat this until the entire front edge of the top is loose from the front panel.
Now lift the front of the top up and allow it to swing up like the hood on a car, let it lean against the wall.
Inside the front of the dryer you will see two screws that hold the top of the front panel to the sides of the unit. Remove these two screws and allow the top of the front panel to come forward slightly so that the felt support for the front of the drum is exposed on the top of the door opening. You may have to push the top of the drum towards the rear of the dryer.
Now pull up on first one side of the front panel and then the other side to disengage the lower portion of the front from the clips on the face of the side panels (they are like little hooks the front panel slips onto).
Once the front panel is loose you can usually swing it 90 degrees out to provide the access you need to your gas valve located in the bottom of the dryer (without disconnecting the door switch.
The drum should remain stationary as it will suspend on the two rear drum rollers while you work.
The gas valve coils are held to the gas valve by one steel cover plate that has two phillips head screws holding it to the valve.
Remove cover plate and wire connections, replace coils and reverse these instructions for re-assembly.
Good luck to you!
Jul 08, 2010 | Roper RGS7646KQ Gas Dryer
How do I get at the valve coil when the dryer does not have a front access panel. Whirlpool LGR4634JQ2
Ok, this dryer actually does have a front service panel, the entire front to be precise.
Good luck to you!
Jul 07, 2010 | Whirlpool LGV4634JQ Gas Dryer
How do you remove the front of the kenmore 80 gas dryer
You need to remove the panel at the top, then you remove the top, then the front, screws for front are inside of dryer. Go to www.appliancepartspros.com and put in your brand and model number. It will pull up all parts for your dryer including schematics that you can enlarge and print of the whole breakdown of you dryer. This will really help you to take apart and put together. Gas coils are at bottom under drum.
May 07, 2010 | Kenmore 72062 Gas Dryer
How do you access the gas valve so the lp conversion valve can be exchanged...front of dryer or back, which panel do you remove
usually you can get to valve by removing front panal from dryer. if not take back of dryer off if need be.
Jan 14, 2010 | Washing Machines
Flame turns on only when dryer is cold, runs for 10 minutes then burner shuts off. The coil glows very bright but the flame does not come on again until dryer has colled way down
The gas valve coils are bad. When they heat up they are losing resistance to stay on.
Turn off the gas. Unplug the machine. Remove the front panel. The gas valve will be in the front right hand corner. Remove the gas valves and replace them with new valves. Please note how the coils orient on the gas valve.
Dec 02, 2009 | Whirlpool GGQ8831L Gas Dryer
How do you convert back from propane to natural gas, I already have the orifice but don't know how to put it on?
If you have the rear control dryer you posted under:
1. Unplug power to dryer.
2. remove two phillips head screws behind door, just in front of lint filter.
3. Use putty knife to push in dryer top release clips at seam with dryer front, about a inch in from each side.
4. Swing top up and remove two phillips screws holding front onto frame at very top of front panel.
5. pull front panel forward a bit and remove plug to drum light and door switch.
6. lift front panel off dryer.
7. Turn off gas shut off and remove burner / valve assembly.
8. Replace orifice and change out brass pressure regulator screw.
9. reassemble and test.
Aug 06, 2009 | LG DLG5988 Gas Dryer
Gas dryer will not stay warm for long
Hi, You will need to replace the coils on top of the gas valve.
There is a small plastic cap that you can remove in the lower front panel. Start the dryer and see if the ignitor glows and shuts off before the gas ignites. If this is the case, the coils need replaced. This is a very common issue with the gas dryer.
Here is how to change the coils:
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jul 10, 2009 | Whirlpool LGR5636L Gas Dryer
KENMORE GAS DRYER DOES NOT IGNATE MOD# 87980800
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, and maybe an igniter all three are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new, if it doesn't then you will need to check the igniter. The igniter is attached to the end of the burner assymbly by one screw and a simple two wire plug. Inspect for breakage, and replace if needed. Happy to help, Tim.
Apr 01, 2009 | Kenmore 73952 Gas Dryer
Kemore Elite Dryer - no hot air
kenmore gas dryer heats at first, then cools off rest of cycle.
Jul 26, 2008 | Kenmore 74602 Gas Dryer
LG DLG5932W Gas Dryer Logo
59 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
