Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Washer sounds like Helicopter
My Bosch nexxt Inspiration washer sounds lik a helicopter when I use anything over gentle spin. a repairman came and 'fixed' it for us about a couple months ago and it was okay for awhile, but its back to its original. I had bought it Brand new from 'Trail Aplliances'
  • Anonymous Jun 23, 2008
    Same loud noise like a helicopter is landing on top of the house. Excessive vibration regardless of load and spin speed; was not balanced by retailer/installer at delivery - I got it balanced (right on the button, according to the Service Tech) - but still vibrates. Now I think I am hearing some bearing noise. Unit is only 3 months old; retailer - SK Lavery of West Hartford CT - has been uncooperative, one person outright rude and has failed to provide any meaningful support and zero corrective action. Not a happy camper.
SOURCE: TURN OFF ALARM
Assuming you have allready checked the operators manual, check again on page 19 for "Accoustic Signal".  To deactivate the signal select a program press two of the option buttons and hold until a short signal is emitted.  There you have it.
Posted on Jun 29, 2009
SOURCE: Washer stopped. E04 beeps but won't spin or continue any cycle. Have shut off machine but only makes a strange sound.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had the same problem. Error code E04 with a full load of laundry and water in the washer. Unplug the power to the washer. Take off the round cover plate in the front right. Mine did not turn clockwise or counter-clockwise, it was completely stuck. Used two flat tip screwdrivers to carefully pry it away, without damaging anything. The plate is a hard plastic but just pliable enough.
Once removed, you will see the pump (img_0001). Unscrew the pump cover slowly. There will be water coming out, so be prepared. In my case we had a LOT of water, so I drained it gradually into a couple of large garbage bags. Wrap the bag opening tightly against the pump surround to minimize spills (img_0002).
Once all the water is gone, remove the pump cover and clean out any items trapped in the pump and in the drain from the drum (img_0003). In my case it was some loose change and a small ColorCatcher sheet. Reassemble the pump and you're done.
Also helpful:
http://www.fixya.com/support/t1589624-bosch_nexxt_dlx_washer_open_round_panel
img_0001
img_0002
img_0003
Posted on Jul 26, 2009
farr64
  • 121 Answers
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Posted on Sep 14, 2009
  • 410 Answers
SOURCE: bosch nexxt series 500. error eo4
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Posted on Nov 29, 2009
barkencoa
  • 3463 Answers
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Posted on Mar 15, 2010
My ge model gtwn4250dws washer sounds like a helicopter during spinning?
The most likely cause of this is that the washer transmission has a defective bearing.
Jan 17, 2017 | GE Washing Machines
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
When my washer is on the last spin it is very loud, almost like it needs a muffler
You didn't say what model washer you have, but it sounds like you have a bad spin bearing. When bearing is bad it can be very noisey during spin, like a helicopter taking off. This means your washer needs a bearing and seals overhaul. This is generally a very expensive repair unless your washer is under some kind of warranty. The spin water seal has more than likely been slowly leaking, causing bearing to go bad.
Jan 31, 2010 | Washing Machines
NOISY DURING SPIN CYCLE
If this sound starts slow and gets faster till its helicopter sounding you probly have a verry worn spot on the drive belt when that spot goes around the pully it will thump the faster ti spins the more frequent the sound If you tilt the washer back you should be able to see the belt to examine it if this the problem
replace the belt
Hope this helps
please leave feedback
Nov 27, 2009 | Maytag Legacy Series Top Load Washer
Bosch washer - taking apart the anti-siphon valve
I have a Bosch Nexxt Washer when it goes into the spin cycle I get EOO2 and the washer stops
Mar 20, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Need repair man for the LG WM0642H washer. I live in northern NJ. Washer sounds like a helicopter at 18 months.
right here on fixya.com...go to the service directory and shop around for your area,,,your spin surport basket most likely leak through the back tub seal..
Jan 06, 2009 | LG WM-2277HW Front Load Washer
Washer will not spin
Carbon brushes in motor have worn down clean armture and replace brushes.
Nov 26, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
My Bosch Nexxt Essence front load washer is making a knocking and squeaking noise during the whole spin cycle. It sounds like it's coming from the drum mounts - what should we do?
My Bosch Nexxt Essence front load washer will not drain. I changed the lint filter, and insured that the drainage hose was free of debris. I removed all the wet clothes, wrung out the excess water, and redistributed the clothes. Still, no draining or spinning. Initially there was a humming sound, but now there is no sound at all when I try to restart the drain or spin cycles. All the lights are appropriately "on".
Apr 13, 2008 | Bosch Washing Machines
Bosch Nexxt washer will not spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Sep 24, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
74 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
