Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Standby LED blinks over and over 9 times
I see the other questioners having the same issue,  What was your solution/suggestion...didn't see that posted.  Thank you! Bob
  • 2 more comments
  • merery May 31, 2008
    Yesterday- all was good
    Today- 1) Would not turn on
    2) Stand By light blinks 9 times (pattern)
  • myth56 Jul 25, 2008
    Yup plug it in blinks 10 times then switches to 9 times. what can i do to fix this?
  • feistychic Sep 08, 2008
    I have the same problem. Stand by blinks ten times then in nine time intervals.
  • tyart22 Sep 13, 2008
    I have the same problem. Stanby LED blinks 9 times and repeats the same.
    I tried to switch on through remote and directly from the TV power switch but it is the same.
    You may send your suggestion to my mail: tyart22@yahoo.com
  • 125 Answers
The G module is bad I found that replacing the g module the problem goes away BUT YOU NEED A TECH to confirm it
Posted on Sep 05, 2008
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
Trouble code: Standby LED blinks 9 times
You will need to replace the G board on this tv to fix the problem
Aug 13, 2008 | Sony KP-51WS510 51" Rear Projection...
I have Sony Bravia model KDL-55NX720 & it won't turn on.It has 5 blinking red lights.According to a diagram that I found for this TV, I have replaced the TCon Board and the LED Panel. Any suggestions?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 14, 2016 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
9 blinks no pic or sound and tried turning off for while and no avail any suggestions or know what 9 blinks suggest?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 13, 2014 | Sony WEGA KE-50XBR900 50 in. HDTV-Ready...
Power LED blinks 9 times
There should be a problem with its audio output board. 9 blinks denotes it. For more details <http://electronicshelponline.blogspot.com/>
May 23, 2013 | Panasonic 32 TCL32C3 32 LCD TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby LED blinks 9 times; TV does not come on
An easy problem for a Sony authorized service center anybody else they may not have a clue.
Mar 27, 2009 | Sony KV-36FS16 36" TV
Repair inquiry
     According to the LED BLINKING there must be some problem that are given below:
Diagnosis item:  Video out abnormality detection
TIMER/STANDBY
Indicater
Number of blinks:
5 times
Supposed malfunction:  Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510,516,524 (A board)
Condition:TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
Self-diagnosis
screen display,
Diagnosis item: Results:   5 : AKB 000
So, This was the result of 5 times led blinking.I would suggest you to please contact any expert or strongly recommend to contact any SONY SERVICE CENTRE for repair because it's not an easy job to rectify this problem. Hope you better understand my sayings.
Thank you for using fixya.
Nov 29, 2008 | Sony KP-53HS10 TV
Fix my tv
please contact ur dealer
Mar 11, 2008 | Sony KV-32S42 32" TV
Try pushing the buttons on the remote and let me know what comes up on the screen if anything.
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
Jan 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
