Question about HP PSC 750 All-In-One InkJet Printer
Message states open ndoor clear carrage jam, I have cleared the Jam no paper in the way wheels are moving freely.
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
Kodak all in one 5500 states paper jam. Nothing works on it.
Nothing will work until you clear the paper jam. Even if there is no paper jammed, you need to open all the access doors and then close them again. The machine will do a reset cycle and then clear the paper jam message. If that doesn't work, then there is indeed a small piece of paper in there. Whenever you get a jam and yank a piece of paper out of the machine, you should flatten it out and verify there is nothing left behind and no bits missing..
Mar 24, 2016 | Kodak Office Equipment & Supplies
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Paper jam - can't clear error message
Hello Nj,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Paper jams are was very common on HP printer model.
Here are few instructions on how to clear the paper jam on your printer.
How to Clear a Paper Jam on an HP Inkjet Printer 1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Look for paper through the opened back panel. Remove any paper you find jammed.
4. Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Close the front access panel. Make sure that it latches back into place.
8. Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this helps.
Aug 08, 2009 | HP Office Equipment & Supplies
Error Message - Paper Jam
I had a paper jam. I removed the offending sheet of paper which unfortunately tore into 4 pieces as it came out. Upon piecing the sheet of paper back together - there is a small piece missing. I've checked the printer thoroughly - nothing can be found!
Feb 25, 2009 | HP Officejet Pro L7680 All-In-One Printer
I keep getting an error (81:01)
The problem refers to basically a paper jam. I thing your problem could however be the carrage movment. There is a special oil required for the carrage, but failid this use a very thin oil such as sewing machine oil. The trick is to not use too much oil, only a drop or two over the entire length of the carrage. Also needs to be oiled is UNDER the rail towards the back. Look carefully at the back of the carrage where it has the back slider. This rail needs to be clean and lubricated. Probable easier to clean and lubricate if you remove the encoder strip.
Regards
Dave
Dec 10, 2008 | HP DesignJet 500ps InkJet Printer
Carrage jam - error message
if you have had this for some time, the ink pads and their well may be clogged with dried ink. look at those. If so, you will have to take them out and clean out the well, then the ink heads should move freely.
Jan 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP PSC 750 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
