Question about Panasonic PT-61D30 61 in. Rear Projection Television
I have a Panasonic Pt-61D30B tv. Just recently the tv started showing a blue shadow around figures. I tried adjusting the convergence but it didnt work. is there a convergence board that i can replace? if so, does anyone know a part number?
  • 7 more comments
  • littlekxride Oct 02, 2010
    ok. I double checked the model number. on the back of the tv there is a white sticker. on it says Model NO. PT-61D30B
    Chasis No. ? EP816
    Serial No. MY02560062
    do you have the part number for the boards you found so far?
    thankyou. hopefully this fixes the problem
  • littlekxride Oct 08, 2010
    replaced those. still same problem
    convergence clips?
    where do i test them at
  • littlekxride Oct 10, 2010
    I have a Panasonic Pt-61D30B tv. Just recently the tv started showing a blue shadow around figures. I tried adjusting the convergence but it didnt work. so i asked an expert. he told me it was the convergence chips. i did this and still the same problem. so now im getting a second opinion. any ideas?
    i changed the convergence ics. still same problem
    i havent changed those. are they the little white things on the board in the picture
    so i would have to replace all of them?
    President:
  • 2,777 Answers
I believe it is the video board itself you want to replace on this unit. I am having a hard time locating this part though, I will keep checking for you though.
Tim
Posted on Oct 10, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs tobe replaced. It's not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you'll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. Please check this picture:
There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Oct 10, 2010
    What about the resistors...
  • Rylee Smith
    Yes you are right
  • 10,594 Answers
Please reconfirm model number of your tv as PT-61D30B sounds incorrect number.
Regarding convergence section/ board, usually there are two big black ICs mounted with big aluminum heat sink on deflection circuit board and ICs number would start with letter STK,,,, these are convergence output ICs that need to be replaced to fix the problem.
Now let me know correct model number of tv to provide you more helpful info.
Thanks.
Posted on Oct 02, 2010
  • 4 more comments
  • Shahid Electronics
    Shahid Electronics Oct 02, 2010
    OK, I got ICs number in this tv,
    STK392-110
    Available in Panasonic Part Store for $29 each (tv needs two chips)
    and also available in Part Store.com for $32 each,
    click part store.com link to view IC image for easy recognition in tv circuit board.
    Thanks.
    STK392-110 is part number of convergence output ICs in this tv
    Also mentioned where you can buy this IC, tv needs two ICs of this same number
    Thanks
    Yes, replacement of these ICs will fix convergence problem,
    you should not attempt to replace these ICs if you have no prior experiences of electronics stuff repair as soldering work with proper tools is needed.
    Local tv repair shop will help you.
    Thanks
    Shahid Electronics Oct 08, 2010
    Make sure convergence chips are getting power that is +20V and -20V
    Convergence chips are those ICs that you replaced in tv, STKxxxx
    They need power supply to work properly so check are they getting volts as mentioned before so they can function to converge the picture on tv front screen.
    Shahid Electronics Oct 10, 2010
    Ok, no problem
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
The blue lense is off by 2 inches and can't adjust it. The picture has a blue shadow.
The tv have a problem known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have 3D pictures or colors shadows.The tv convergence board it dead.Require changing 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 08, 2010 | Panasonic PT-47WXD63 47 in. Rear...
Panasonic PT47WX54J is showing a red shadow behind words and pict
you need to go to your remote, look up menu. then select "convergence"...this will give you a "crosshairs pattern to align your "guns" ...it has three red, blue, and green.....try not to move the TV around too much....its knocking them out of alignment
Oct 01, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Blue/yellow shadows
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
Aug 23, 2009 | Panasonic Televison & Video
Panasonic PT-60LC14 Convergence Issue
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 06, 2008 | Panasonic PT-60LC14 60" Rear Projection...
COLOR SHADOW
This tv does not have a lamp. If you can not adjust the convergence, then that is the problem. Yes the amps will have to be replaced. I would get this fixed and not scrap it. You can try and replace the amps if you find the need to or have a repair shop do so.
Jul 21, 2008 | Panasonic PT-56HX41 56" Rear Projection...
Convergence
When this happens it means the convergance Ic's have failed ( STK392-110's) they will need replacing then the cross hairs will move again
Feb 07, 2008 | Panasonic PT-56HX40 56" Rear Projection...
Panasonic PT-61D30 61 in. Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
