Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
My WAN is functioning, but my WLAN is not. I have reset both the modem and the router multiple times. What should I do?
    Brigadier General:
  • 10,406 Answers
Connect an Ethernet cable between the network-port on your computer and one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG/RENEW
Look for output like:
Default Gateway.....192.168.123.456
(Instead of '123.456', you'll get some other numbers!)
Start Internet Explorer.
Type http://192.168.123.456 (use your numbers!)
Login to the router (ID: admin, password: "blank")
Click to run the Wireless Networking Setup Wizard
Configure a SSID, an encryption-level (use 'WPA')
and a network-password.
Now, your WLAN will be ready to use.
Posted on Oct 04, 2010
Wlan light blinking
It may be the router is not getting wan connection from the modem. Depending on the technology the ISP is using, it could be that they need to allow to assign an IP to your router or there are confliction of configuration or cable connection type between your router and the modem. Or the service to your modem is interrupted for some reason. Try to skip your router and see whether your computer works by connecting it to the modem directly. If that works, reset the router and reconnect it to the modem and see.
May 26, 2016 | Computers & Internet
Which wires on the Cat5 are connected to the WAN Port
Cat 5 is a cable configuration standard that uses a plug and jack that is similar to a modular phone jack called rj45. Those cables plug into multiple points on the router. If you have a separate cable modem, the cat 5 cable from the modem connects to the WAN port on the router.
Mar 08, 2016 | Computers & Internet
SMCWGBR14 N only power led
Resolutions:
1) Power on the SMC modem / router and wait until all the lights are light up.
2) Press and hold the reset button for 15 seconds and wait until all the lights are light up as the modem / router needs to reboot.
3) Try to access to the admin page again by default login IP - http://192.168.2.1/.
4) Enter the default login password.
a) smcadmin
b) (blank)
c) barricade
Nov 25, 2013 | Edge Barricade 4 Port Broadband Wireless...
INET light is on not able to connect to internet
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Oct 18, 2013 | D-Link 802.11g Wireless Router WBR-1310...
Is there a way i can hook up internet to 2 desktops with 1 modem/router?
That is exactly what a router is for.
If your modem doesn't have multiple ethernet connections, then go out and buy a generic router (like linksys or belkin or cicso or netgear, etc.) and hook the WAN port of the router to the modem's ethernet connection, and then hook the computers into the multiple ethernet connections on the router.
Aug 24, 2011 | Computers & Internet
HVING PROBLEM ACESSING THE INTERNET THROUGH THE ROUTER . WIRELESS OR HARD WIRED . IFI RUN STRAIT FROM MODEM I HAVE INTERNET . ONCE CONNECTED TO ROUTER I DONT
connect the router wan port to one of the modems lan ports,
then connect to the router per lan or wlan and everything works.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
I think i hve the router hooked up wrong how do i fix it
Connecting Multiple Computers
thru a router to internet
Tips on choosing the right network can be found at http://www.microsoft.com/windowsxp/using/networking/setup/install.mspx
Since you said there are other computer in the house I assume they will all
go thru the router. I also assume you are using ethernet to connect the new
computer so it will be a "wired" connection. A rounter can also have wireless
connections if the other computers have wireless internet on the other
computers.
To connect more than one computer to the Internet, you need a router.
A router allows you to connect several computers to each other and to the
Internet. The router sits between your computers and the modem provided by your
ISP. You connect the router to the modem, and then connect all your computers to
the router.
To connect a router and multiple computers to the
Internet
Contact an Internet service provider (ISP) and have them configure
an Internet connection to your home. If possible, have the ISP place the modem
in the room with your primary computer.
Connect your router to your modem in one of the two following
ways:
If you currently have a computer connected directly to your
modem:
Unplug the network cable from the back of your computer, and
plug it into the port labeled Internet, WAN,
or WLAN on the back of your router.
If you don't currently have your computer connected to the
Internet:
Plug one end of a network cable (included with your router)
into your modem, and the other end of the network cable into the
Internet, WAN, or WLAN port
on your router.
Plug in your router. After a minute or two, the Internet, WAN, or WLAN light
on your router should light up, indicating that it has successfully connected to
your modem.
Determine whether your computer has a network adapter, and add one if
necessary. Instructions to determine if you have a network adaptor or to install
a Network adaptor can be found at http://www.microsoft.com/windowsxp/using/networking/setup/netadapter.mspx
Shut down your computer by clicking Start and then clicking
Turn Off Computer. Then click Turn Off.
Connect the network cable to your computer's network adapter.
Connect the other end of the network cable to your network equipment.
Start your computer and log on to Windows. Windows automatically detects that
you are connected to the Internet.
Repeat steps 6, 7, and 8 for each one of your computers. If you have a
computer in a different room you can find instructions at http://www.microsoft.com/windowsxp/using/networking/setup/wired.m
Feb 15, 2011 | Zonet ZSR4154WE 80211N Wireless Broadband...
SMC2804WBR router: The lights are on but nobody's home.
Sounds like the router is about to die. I had the same issue with a wireless router a few years ago. It would broadcast but I would not be able to get onto the wireless no matter what I did but plugging straight into the modem and it worked just fine. If you've done a hard reset and it is still not connecting or staying connected, it is about time to replace the router.
Nov 17, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Wlan lights off and now wirless access
Does your computer say Network cable unplugged?
If the wlan light is off, it means that your computer is not being detected by your router. You can try unplugging and replugging the ethernet cable at the back of the computer. Make sure that you hear a 'click' when you plug it back in to make sure tha it is properly seated. Check also the light on the wan port (desktops usually have lights..not sure about laptops though).
Do the same process with the ethernet cable but now from the other end--the one connected to the modem/router. if your modem/router have other ports on it, try to connect it to other ports as well. If you're wan light is still off, try using a different ethernet cable.
what's wrong with your wireless access? i can't read it from the title.
May 04, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
54 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
