Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Freezer seems to be working fine. refrigator does not seem to be cold enough
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 01, 2010
I have model number PDE18LZRBB. Freezer works fine; refrigerator section will not cool properly.
Your problem is usually caused by poor air circulation. The only way the refrig section gets cold is from the fan in the freezer blowing cold air into the refrig section. The fan should be behind the back wall of the freezer and should be running at the same time the complete refrigerator is running. No fan run---no cold in the fresh food section.
Apr 01, 2015 | GE Refrigerators
Refrig will not get cold freezer is fine, fan was sounding very loud last week but it stopped making the loud noise n the refrig seemed fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 25, 2011 | Samsung RF265AA Bottom Freezer French Door...
Frigidare refrig. It seems like Freezer still working but not refrig. Temp is now 56 in refrig part. Refrig is not even 2 years old. Fan seemed to be working in refrig earlier but now not at all.
check the damper vent door between the two compartments to make sure its open to let the cold air in from the freezer then make sure the evaporator fan is operating to help push air thru this door,sometimes these doors freeze shut or if its a motor driven vent door the motor could be bad too
Jan 01, 2011 | Refrigerators
Freezer is working properly but fridge doesn't seem to be. Light not coming on and food not cold enough, though not there seems to be some cooling
check that the damper door between the refrige and freezer is operating with the refrige adjust control,sometimes they ice up in a position and cant let cold air in to the refrige,deice it with a hair dryer and then adjust that control and watch if it moves open or closed
Mar 09, 2010 | Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
My Maytag Plus side by side is cold in the freezer but not cold enough in the refrig part despite turning the refrig control to a colder setting. No air seems to be blowing out of the air circulator vent.
this is usually a problem with evaporator fan not turning when the unit is running.check the freezer compartment and listen to the fan if it running. if it is not running it needs to be replaced.one good indication is ice or frost build up on the rear of the freezer compartment
Sep 16, 2009 | Refrigerators
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
143 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
