Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana sxd22s2l keeps going into defrost mode - Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
My amana fridge model number Arb1914cw isn't cooling but the freezer is working
ur defrost terminator is bad and is not going into defrost cycle? and this will stop the fan from circulating the cold air. the heat is only suppose to last up to 20-30 minutes then back into defrost mode? if the defrost timer is bad heres a trick u can use that may get u back into defrost mode, locate the defrost timer in ur fridge usually at top center. then under the timer u will see a tiny slot or hole. if u stick a small screw driver into that hole and turn slowly clockwise till u hear it click? i, it will now go into defrost and u should hear the fan and the compressor go off , hope this helps let me knoiw if u have any more questions, lastly I suspect its not ur timer but ur defrost terminator> meaning is will not allow it to go into heat defrost. its easy and relatively inexpensive.
Mar 16, 2015 | Amana Refrigerators
My Amana refrigerator defrost timer is supposed to cycle every eight hours. Instead it takes about 14 hours to cycle around back to the defrost mode. The defrost mode does last for the proper 20 minutes....
Relax, some people exagerate was all I was saying.
Anyhow, go to a good parts store and ask for a Supco EDT (Electronic Defrost Timer) replacement as they are more reliable and not much difference in price.
May 15, 2010 | Amana ABB1921DE Bottom Freezer...
Fridge freezer keeps going into defrost mode every couple of days, last time it wasnt cooling for two days ?
All units enter a defrost every 6-8 hrs, I think youre timer is hanging up and sticking in defrost mode.
Apr 24, 2010 | Amana Refrigerators
Fridge & freezer work fine but there is water running out from under it. no ice maker on this model.
the freezer has a defrost timer on the evaporator coil to keep it from freezing up and restricting the air flow to the box. It may simply be going into defrost mode to often and filling up the condensate pan. The adjustment on the timer is internal near the rear and should be done by a servvice tech
Nov 26, 2009 | Amana ABB1927DE Bottom Freezer...
Amana side by side fridge model sxd22s2l freezer/fridge not cold
they can get up to 305 degree F they can make brown spots on floor... yes they get very hot(is normal)
Aug 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Stuck in defrost mode after changing timer and thermostat
Amana adaptive defrost:
Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 05, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana side by side not cooling well, will not freeze water.
if you are only seeing frost on the top portion of the evap coil then you then it sounds as if the unit has sealed system problem (low freon or bad compressor). if the unit is less than 5 years old and made prior to nov '06 it should have a sealed system warranty. if the unit is out of warranty you may want to start looking at new refrigs. good luck peyton
Jan 24, 2009 | Amana ARS2464B Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
63 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
