Question about DeLonghi Coffee Makers & Espresso Machines
Delonghi Magnifica Rapid Cappuccino machine has stopped making steam. It continues to brew coffee but when I turn the steam know to steam a stream of water flows for a few seconds and then nothing except the occasional drop of water. It had allowed me to froth milk an hour previously but has now stopped. I've descaled the unit but it hasn't solved the problem.
  • oded Feb 01, 2012
    it does not help, I made sure both holes are clean but the machine will not steam at all...frustrating !
    I descaled it and made sure all clean cycles run through but nothing solves the issue ... any advice will be MUCH appreciated.
  • 1,041 Answers
Your problem is the holes in the cappuccino maker and
steam nozzle are clogged. Clean the holes in the cappuccino maker and the steam nozzle.
IMPORTANT: Before cleaning the holes in the steam nozzle, make sure that there that it is not hot and there is no pressure on the machine.
I'm sending you a free pdf manual download of what I believe to be your machine. If this is not it, give me the model # and I will try to find it.
Good Luck!
Jim
Posted on Oct 01, 2010
  • Jim Parker
    Jim Parker Oct 01, 2010
    Sorry, I pushed the SOLVE button before I sent you the Link. You will have to copy and paste it in the address bar at the top of your screen.
    www.delonghi.com.au/support/instruction_manuals/EAM3400.pdf
    Jim
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Why won't the steam function work on my brand-new out of the box DeLonghi Magnifica Espresso Machine?
The steam heater is probably not working. Check your manual to see if there is a fuse or reset switch for it. If that doesn't work, return the machine to where you got it for an exchange.
Aug 30, 2015 | DeLonghi Magnifica Coffee Makers &...
Delonghi Magnifica 3300 doesn't make coffee, only wet grounds and water in the grounds container, everything else seems normal
Hi JB, not sure if you've junked your 3300 machine by now or had the problem fixed already. Nevertheless, allow me to share with owners of DeLonghi Magnifica Espresso machines who encounter similar problem to yours. Incidentally, mine is a Delonghi Magnifica 3200 which is very much the same as the 3300. Firstly, try to ascertain if the pump is working normally. When the machine is ready to brew coffee, turn ON the steam/hot water knob and see if it pumps normally and for more than 30secs at least. My machine could pump for short durations between 5secs to 20secs max before the water light came on. I checked the flow meter connection but is all seemed well. I noticed signs of water leak (dried up chalky water stains) where the steam wand exits the control panel. Upon opening up the control panel, I noticed a larger patch of dried up water stains on the wand valve assembly. Bought a set of steam wand assembly replacement and to replace the leaking one. It's been some six month now and I'm enjoying my daily cuppa again. Btw, my Delonghi Magnifica 3200 has been serving me well for 10 years! Apart from the steam wand replacement and a faulty micro-switch, I only had to carry out the usual descaling and replacing worn out O-rings.
Feb 10, 2013 | DeLonghi Magnifica 3300 Espresso Machine
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi magnifica rapid cappuccino model EAM 3400.S KEEPS SAYING INSERT THE INFUSER, I HAVE PUT THE INFUSER IN AND IT HAS CLICKED BUT IS STILLS SAYS INSERT THE INFUSER
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
Nov 28, 2010 | DeLonghi EAM3400 Espresso Machine
Coffee Makers & Espresso Machines Logo
895 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
