Question about Bosch 13618 2G Factory Reconditioned 18V Bluecore Brute Tough 1/2" Cordless Hammer Drill/Driver
The chuck is stuck and cannot remove a drill bit.
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
comax
  • 154 Answers
SOURCE: Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Posted on Apr 13, 2009
SOURCE: The quick clamp chuck on my bosch 600 has seized
Hit a metal part of the clamp chuck to just create a "shock" using a hard rubber-hammer (or a metal hammer if the rubber one fails) one or two times. Chuck grip will loosen on the bit for you to remove it.
Posted on Dec 24, 2009
comax
  • 154 Answers
SOURCE: how to remove bit retainer or chuck from drill
Grasp the chuck and twist the sleeve counter clockwise and pull up.It will come off. To replace the chuck slide it back onto the drill shaft, grasp the chuck collar, twist it counter clockwise and push down on it, it will slid back onto the shaft and lock into place.
Posted on Jan 09, 2010
  • 10865 Answers
SOURCE: A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Posted on Jul 19, 2010
How to remove bit stuck in kango drill
Hello, You might try spraying some wd-40 in the chuck to let soak and loosen up, to be able to turn and remove the bit.
May 15, 2014 | Drills
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
I have a DEWALT DC920 drill-driver and have a bit stuck in the chuck. The chuck adjuster appears to be stripped. Need to remove the bit and replace the chuck. Any ideas on how to get the bit released?
try tapping on all sides of the chuck lightly with a hammer and wiggling the bit... you can also try to spray some oil into the chuck and see if that loosens the bit for you... You can also clamp the bit in a vise (or get someone with a pair of pliers) and pull, that will sometimes do the trick.
Apr 04, 2011 | Dewalt 18 Volt Compact Drill Kit
Jul 19, 2010 | Bosch Drills
How do I remove a stuck bit from the chuck?
put the drill in a vice. then use the chuck key  and a hammer to release the bit.
 if necessary use wd40 spray to free up chuck.
Jan 24, 2010 | Black & Decker 18V Cordless Drill/Driver
Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Mar 25, 2009 | Makita Drills
Chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
Mar 09, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Bosch 13618 2G Factory Reconditioned 18V Bluecore Brute Tough 1/2" Cordless Hammer Drill/Driver Logo
87 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
