Question about Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range
Whirlpool model GS563LXSS oven and broiler wont ignite. Top burners ignit.
  • 1314 Answers
SOURCE: Whirlpool Super Capacity 465
you need to replace the oven ignightor trybroil and see if it works if it does the bottom ignightor is bad
Posted on Jan 20, 2008
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
onthejob5130
  • 640 Answers
SOURCE: Stove Top Ignition will not turn off
all ignitors lite thats the way the stove works thats a safty feature..but im thinking your question is they wont go off,,if thats the case replace spark module...if not im here onthejob
Posted on Jan 04, 2009
SOURCE: whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
Posted on Jan 08, 2009
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
The gas is connected on the rear side of the stove but the pilot light is not lit, nor will it light. trying to trouble shoot the problem before deciding to purchase a new oven/range. Also, I remember...
You may have a pilotless ignition.Check around door frames for model #plate.
Also , open broiler door ,turn on oven and look inside . If you see an orange glow appear after awhile, that is the electronic igniter and you have an electronic ignition(no pilot).In this case the top burners use a spark ignition system.If you don,t hear clicking when you turn on a burner your ignition module might be bad.
Easily fixed though.
Aug 18, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Oven wont fire
99% chance the igniter is the issue.
Nov 30, 2009 | Washing Machines
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool super capacity 465 oven quit lighting
Check the burner ports near the ignitor for blockage. I had one of these units, and the ignitor was not mounted correctly, and caused a similar problem
May 02, 2009 | Ovens
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Whirlpool oven doesn't work model gs563lxss
May 15, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range Logo
51 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
