Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker XL1800 - open the door and it starts buzzing - unplug and it quits - plug back up and push any button and all it does is buzz - will not do anything else
  • GE Master
  • 9,047 Answers
That's a defective electrolytic capacitor on the control circuit board.
We see and repair this a lot nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Oct 03, 2010
Testimonial: "I don't know anything about repairing a microwave, but the advice sounded like I could even do it. Thanks for the answer"
XL1800 buzzes but heats
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may have to replace the capacitor too. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
May 11, 2013 | GE XL1800 1100 Watts Microwave Oven
My ge xl1800 has 50 volts at the fan when the fan switch is off. it hums because of the low voltage. it works fine when the fan switch is turned on. the fan cap checks out fine
If you have had trouble with the cooktop lights recently, or if you get a hum or buzz in the area of the control panel assembly when you open the door, either indicates that you need circuit board repair. More details here.
Jan 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave JVM1851WD001, buzzes if you open the door, buzzes if you push any buttons but will not start. The light is on if you open the door and the digital clock is working.
That is a control circuit board issue which we regularly repair with our $39.95 service nationwide.
Or if you prefer, you can order a new smart board / PCB assy (part number WB27X1043) from the Pros here, our favorite supplier. It runs $259.53.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker XL 1800; Model JVM1860 CD 001; Manufactured Nov. 2001 When opening the door or pressing any menu option, a constant buzzing sound occurs. The unit does not respond other than the...
We see (and repair) this a lot. The problem is electrolytic capacitor that fails on the control circuit board, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year repair guarantee.
Nov 22, 2010 | GE XL1800 1100 Watts Microwave Oven
GE Profile Space,aker 1800 microwave is making
You should keep it unplugged until it's fixed. If it's cooking while it should be off, that can damage the oven or even start a fire.
It's either a failed door switch or door switch mount, or a bad electrolytic capacitor on the control board, which we can repair for $39.95.
If you're hearing a fan or motor running, I'd suspect the switch. See this file for help.
If it's a buzz (like a power line buzz) then I'd suspect the board capacitor.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 24, 2010 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 Buzzing
Chances are this is a problem on the control panel. We repair these for customers nationwide with our guaranteed $39.95 service.
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Jul 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
708 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
