Question about Frigidaire Gallery Side By Side Refrigerator 26 Cu. Ft. GLHS69EEP
The icemaker on my 10 year old refrigerator doesn't work. How do I turn it off so that it woun't inject water every 15 minutes or so?
  • 1,040 Answers
There should be a shut off valve somewhere along the water line. It may be right behind the fridge, or in your basement somewhere if you have one. You just need to follow the water line to the valve. Once you find the valve, turn the handle clockwise until the handle will no longer turn. The water will no longer flow o your fridge
Good Luck!
Jim
Posted on Oct 01, 2010
Water & ice in bottom of freezer
Sounds like there is a damaged water line that is leaking into the freezer.
Aug 02, 2017 | GE Refrigerators
In door ice maker not turning
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Kenmore Side by Side Refrigerator
The icemaker in my 10 year old side by side Galery series refirigerator doesn't work. How can I turn it off so that it doesn't use water every 15 minutes or so?
lifting the arm on the side of the ice maker will prevent the ice maker from cycling, assuming there is nothing wrong with the ice maker. However, simply turning off the ice maker may not prevent any problems you may be experiencing
Oct 01, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a 15 year old GE fridge with an icemaker that has started
You can buy a new icemaker from Home Depot your is probably rotted. Unplug the appliance and unplug the icemaker then remove the screws.
Sep 24, 2009 | Refrigerators
About every 15 to 20 minutes there is a buzzing type sound that lasts between 5 -10 seconds. Then the compressor goes on and refrigerator works fine. Temperature in freezer and refrigerator are correct. It...
Sounds like you have an icemaker that is not connected to water . You need to turn the icemaker off at the icemaker . The buzzing , is the water valve behind refrig , being called for but no water to deliver .
Sep 09, 2009 | GE Refrigerators
Icemaker noises on almost new GE Profile refrigerator
I have not heard of this issue but if it is coming from the icemaker, then it will have to be replaced. You are still under warranty so call to have them replace it now, otherwise the new icemaker will cost you about $125.
Feb 25, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Hotpoint ref'r icemaker does not work.
I defrosted the freezer, overnight. After turning it back on in the AM it worked.
Feb 20, 2009 | Hotpoint HSS25GFP Side by Side...
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water not flowing to Ice Maker
take your icemaker back out and take a hair dryer and blow it up the tube probably 10 to 15 mins
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker repair and still no ice
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser . The valve that the ice-maker relies on may be bad,
  • or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • Note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
btw- you can replace the whole icemaker system for around  $115.00.
  • charging you $250 for a $20 drive motor is ridiculous! my 12 year old son can change the drive motor in 15 minutes.
Jul 06, 2008 | Refrigerators
Frigidaire Gallery Side By Side Refrigerator 26 Cu. Ft. GLHS69EEP Logo
49 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
