Question about Refrigerators
I have a Sears Coldspot refrigerator: The top freezes great, however, water is leaking from somewhere and it is settling in the bottom of my refrigerator where the vegetable trays would be. Turning the temp up does not stop the water leak, it only freezes everything from ice cream to my lettuce. What do you think is wrong?
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 01, 2010
FRIDGE WITH FRENCH DOORS AND FREEZER ON THE BOTTOM. WATER IS LEAKING FROM SOMEWHERE AND SETTLING UNDERNEATH MY DELI DRAWER TRAY. SOME OF THE WATER IS FROZEN. I HAD TO TOWEL THE WATER UP AND PRY OUT THE...
Your model must also have an evaporator on the top section because if the fresh food section deli has water below the trays you either have a door seal leak allowing moisture in or the fresh food section evaporator drain is also blocked. I really think your defrost drain is blocked and now everytime your refrigerator goes into defrost the condensate remains inside your refrigerator. Click Here=> Leaking Refrigerators Just What may Be Happening and read that page and then click here=> Leaking Refrigerators Read over all of the different ways leaks happenn and if this solution is helpful please rate the solution because I need all the rate's I can get. If you have questions I will be here so please ask, Thanks, Sea Breeze
Jun 29, 2011 | Refrigerators
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
It's a Kenmore Coldspot that was manufactured in 1998. There's a tube that gets plugged, water freezes underneath the shelf in the freezer and water starts dripping down into the main chamber. I cannot...
The tube is located in the bottom of the freezer compartment under the coils. To access it, remove the back panel and then the floor of the freezer. Remove all of the ice. Melt the ice that is clogging your drain tube. You should see the drain tube somewhere along the bottom of the back wall. I use my wife's hair dryer or hot water when I do this to my refrigerator.
Feb 05, 2010 | Kenmore Refrigerators
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Jan 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
