Question about Kitchen Ranges
A Maytag washer--model#LAT9206AAE worked perfect--then all at once started walking & vibrating on spin.Theres nothing broke--loose or worn.Washer looks like brand new inside. Damper pads are in place(used to see some half way out or one completely out)Washer is about 13 yrs. old.I,m not sure what could cause the problem--that style Maytag was an excellent machine. Rene
  • Rene Matz Oct 03, 2010
    Hi
    Because of the age of the washer this couple had already gone out shopping for
    a different one--guy,s wife liked the Kenmore Oasis.
    Thanks again. Rene
  • Kitchen Ranges Master
  • 4,924 Answers
Check the horizontal position ...and not to have balance on the legs...and also ..check the counterweight under not to be loose and cause the vibrations that make it move ..
Posted on Oct 02, 2010
  • Catalin Turcu
    Catalin Turcu Oct 03, 2010
    The age always have a word to say in this maters..and the problem is obvious caused by it ...but I was pointing the only issues that may be on ...only the vibrations in excess can cause it to dance around the floor ..and these are cause by unbalance of the feet or ..or the counterweight being loose..and causing the vibrations..
Have a Roper (Whirlpool) top load washer Model RAL 5144BWO, that vibrates excessively. I ran it without any clothes, and still vibrated excessively. I watched it go through the spin cycle with the lid...
Hi, Well it sounds like either one of the tension springs that hold the outer clear tub to the frame down below came off or broke, or that the basket or gearbox shaft is warped. One other thing to try is the back feet on those washers are spring loaded to take out some of the vibration, if those feet arent level it will make the washer shake. it is easy to reset those so they are level. Stand infront of the washer and grab the back of the unit and pull it towards you so that you raise the rear legs, then simply set it back down. To check the spring you will have to take the outer shell off and look at the springs that are at the bottom of the tub assembly holding the tub down on the frame. Good luck and I hope I was some help.
Dec 09, 2010 | Washing Machines
Maytag hav2557 vibrates excessively
sounds like the drum is loose. remove softener dispenser, usually a plastic hand nut, then you should see the drum nut, may be under softener goop though. check if tight. other thing could be one of the drum stabilizers broke, usually drum has 4 of them attaching drum to dryer frame. place unit on side and check
Aug 12, 2009 | Maytag HAV2557 Top Load Washer
Front load washer shakes violently during spin cycle
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Mar 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Unending Heavy Vibration on Spin Cycle - Maytag Neptune
level the machine, if you are on a wood floor it could be the floors fault, you could try using aanti vibration pads.
Feb 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag MAH4000AWW washer jumps around on the spin cycle ...
ok we going to have to take a look at a few things ok...now first just take the back off ,,4 screws phillips screw driver,,you see the dampres are they still together...,,yes walk to the front of the machine and jump up and down do thing in the room,,bounce to...if so weak floor put a plush peice of carpet under unit,,,keep me posted because there a few mor remedies,,if theses did not work..onthejob
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
VIBRATION
The sensor would help it detect vibration and go back to settle mode and restart the spin.
If you have abnormal vibration all the time be certain
1st that machine is really level. can you push or pull the machine when it vibrating and does that stop most of the noise. if so it is not really level.
then open the top (3 screws in top rear)
remove power to unit as you want to live.
Check the suspension and springs they should act like your car.
look,feel, nothing should be loose or disconnected.
the concrete balances should not be loose or cracked.
push on the basket it should resist in all directions.
Jan 28, 2008 | Maytag MAH8700A Front Load Washer
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
