Where can l buy a replacement touch pad for my danby keg fridge?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
Depends on model, i'd call them directly at 800-263-2629 or call their office during normal business hours at419-425-8627
also try Consumer Help Line
1-800-26-DANBY
(1-800-263-2629)
Hours of Operation:
Monday -- Thursday 8:30am - 5:00pm EST
Friday 8:30am - 4:00pm EST
Posted on Oct 01, 2010
I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
May 01, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
Tip
Danby Kegerators
Just some general info on Danby Kegerators. The temp fluctuation is 32-42 degress thru out the day and for 1 hour a day you will get a temp of 46-48 degress during defrost. Unfortunatly there is no way to bring these coolers colder than 32 degrees.These Keg coolers need to be in a temp controled enviroment and if it is enclosed in a cabinet you need to have 3" opening on all sides for air to circulate. Some of the main fault codes are EE = open sensor and LE = which is a communication error between the display board and the main board. The LE error may be in the touch pad which gets moisture in the membrane and causes the pad to quit responded. A lot of the errors are caused by a loose connection. There are 3 screws that hold the table top down, once you get the table top up you'll see the connectors to the boards and sensor, just start removing the connectors, straighten the pins and reinsert them. Also if you ever have an issue with the fan motor, that part is no longer used on these keg coolers, the replacement board assm no longer has a connection area for the fan so the fan can be disconnected if it causes you issues. Another handy trick is to put turtle wax over the touch pad were you select the temperature, then that way the spilled beer will roll off the touch pad instead of ruining it :-)
on Jun 20, 2012 | Refrigerators
The temp guage does not work and when the keg cooler is plugged in it gets down to 20 degrees and freezes the beer. Can this be fixed?
This solution probably costs more than you care to spend on the problem, but you can buy an external temp controller like this one:
http://www.amazon.com/gp/product/B0002EAL58
You run the probe into the fridge and plug the fridge into the controller. Then the controller will only turn on the fridge if it gets warmer than the temperature you specify.
You might be able to find it cheaper on ebay, too. I'm using this on a kegerator and can keep my beer at a consistent temp.
May 10, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
I have a danby kegerator and i just tap the keg and all its doing is spitting air with some foam and i tasted the beer it was completly flat i need help asap!!!
try changing kegs sounds like the tube in the keg is broken the keg has a tube that runs to the bottom of the keg inside and u push air into the keg to push beer thru that tube and into a cool glass and down to ur gulletbut it sounds like u have a defective keg or an empty keg
Feb 24, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Inside fan on Keg Cooler needs to be replaced
Call them and ask to buy the part it should be pretty cheap. I just bought a replacement keypad for mine and they sold it to me right on the phone no hassles
Jul 23, 2009 | Danby DKC645BLS Compact Beverage Cooler
Where can I get a new temperature touch pad?
try "Appliance Parts Pros" web site, I've had great luck and fast shipping,if they dont have it they will go to bat and try and find you one prices are very reasonable cal then or chat online they're seem to want to help you out always.....good luck
Jul 10, 2009 | Danby DKC645BLS Compact Beverage Cooler
Temp wont go below 60
Very simple. Call Danby at 1-800-26-DANBY and tell them the issues you are having. The reps there are very knowledgable and more than willing to help. I just had to replace a computer pad and they are awesome to deal with. FYI, the owner's manual does not have a parts listing. Good luck
Mar 31, 2009 | Danby DKC646BLS Full Size / Pony Beer Keg...
Temperature on Keg Cooler (DKC644BLS) is dropping below freezing
Mine did this as well. last night the diplay read "LE" and the temp controls and the C/F buttons were unresponsive. I called Danby. Although I was on hold for 30 minutes, when they did answer they were very helpful. As mentioned elsewhere here, the touchpad has gone bad. You can order it right over the phone. The price of the touchpad is only $2 and shipping is $7. I ordered 2 of the touchpads (why not, right?) and the shipping was still $7 for the both. # for Danby is1-800-263-2629. Make sure your phone is charged.
Jul 23, 2007 | Danby DKC645BLS Compact Beverage Cooler
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
