Question about T-Mobile Sidekick II
Not Charging I plugged my SK2 in the charger and it won't charge. The camera lien in the back of the phone is flashing different colors.What do I do????????
Take it to your nearest T-Mobile store or Ring Customer Support
They will help.
Posted on May 31, 2008
My phone shut off and won’t turn back on. I cannot remove the battery with the ZTE Max Z981
Check up battery is fully charged.or charging when charger in plugged in.If not charging check up charger working with some other phone .
If the battery is old enough replace battery or check up micro usb in phone thro' mechanic.
Oct 03, 2017 | ZTE Cell Phones
My Nokia E73 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 15, 2012 | Nokia E73 Mode Cell Phone
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
When i plug my charger in i have to move it around for it to start charging and if i move my phone it quits charging its not the chargers i have tired im thinking it my phone. what do i do?
The charging socket on you phone needs to be resoldered, OR the plug on the charging adapter is faulty and needs to be replaced.
To determine which is faulty, use a different charger and plug it into your phone and move the charging plug to see if the it quits charging. If it quits charging then the charging socket on the phone needs fixing (re-soldering).
May 07, 2011 | Cell Phones
When charging the phone, the battery icon flashes off and on and the phone make a sound is it charging properly
hello,
it is not supposed to make any sound when charging, if it does it means there is a problem somewhere.
it is not charging properly. try to turn off the phone and plug the charger. its supposed to bring up a light the show the battery meter and show it charging bar by bar, if it doesn't come up this way, try using the same charger on another phone to see if the charger is working. anything you detect, try to replace the battery and try again.
Jan 27, 2010 | Motorola Mobility W377 Met Silver/Pink...
Can i charge the camera other than through the usb cable ??
Hi!
USB charging is not possible. You need to have the battery charger to be able to fully charge the battery. This should come along with the camera kit.
USB charging is possible if you will buy this: http://fujifilm.co.uk/consumer/digital/digital-accessories/usb-chargers-travel-adaptors-153171/world-adaptor-plus-usb-charger
"For charging by USB, simply change the head and plug in your iPod, mobile phone, PDA or any other 5V USB powered device to keep it fully charged wherever you are."
Aug 25, 2009 | Fuji Finepix Z20fd Digital Camera
Nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
LG Secret charging
Dr Know, doesn't know what he's talking about. I have a LG KF750 and have experienced the same problem.
Solution - Really jam the cable into the socket! The connection is pretty rubbish. The phone charging icon will (with some force and wiggling) appear on screen. Then carefully put it down and don't touch it!
USB charges very slowly, if charging from a dead flat battery it may take a good 20mins of charging to boot up.
P.S. the red camera light is not supposed to come on when charging. Keep wiggling the cable and the light will go off when the phone charging icon appears.
Dec 16, 2008 | LG Secret ? KF750 Cellular Phone
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
T-Mobile Sidekick II Logo
23 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
