Question about Delphi SKYFi3 XM Radio Receiver
How do I use a new MicroSD? Unit locks up when Checking Media
  • Delphi Expert
  • 509 Answers
First of all, suggest using an SD card of 2GB or under. Second, firmware update. Here's the details: This is a common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
You will need to update your firmware on the radio using the baby USB cable and the unit plugged into your computer WITH the battery recharged FIRST. Also, go to the www. xmradio dot com website and download the SkyFi3 FIRMWARE update. Then you need to download the "firmware update" into your SkyFi3.
If this doesn't fix your lockup problem, you need to call DELPHI customer support, and they can tell you one more 'master reset' method. After the firmware update, it might take 2 or 3 'restarts'.
Again, press and hold the Volume UP and PWR at the same time to reset a 'locked-up' SkyFi3. Regards, John
Posted on Oct 06, 2010
I imported pictures and it doesn't show on my sansa it says unsupported media format
The Sansa Media Converter (SMC) software is required to convert and transfer videos and photos (pictures) to your Sansa player as well as the memory card in your Sansa player.
NOTE: Only the Sansa e200v2, Fuze, and View allow viewing of video files from the memory card.
STEP 1 - Download and install Sansa Media Converter
The Sansa Media Converter application is available via the Sansa Firmware Updater.
STEP 2 - Convert and transfer your video or image files
NOTE: To see a list of supported image/video file formats, see Sansa Media Converter does not convert a file
1. Run the Sansa Media Converter.
2. Connect the Sansa player to the PC.
3. If a Portable Device windows appears, select Sansa Media Converter using Sansa Media Converter.
alt="Image">
4. The Sansa player should appear on the left pane of the Sansa Media Converter console.
alt="Image">
5. Click Add Media to add video or photo files to be converted and transferred.
alt="Image">
(In the sample below we imported an image and a video file)
alt="Image">
6. The converted files are stored in My Album by default. To place them in a different folder, select My Album then type in a new name.
alt="Image">
7. Depending on what Sansa player that's plugged in or if a microSD is present in the Sansa player, click on the Sansa player or the microSD card on the left pane to select where to transfer the converted files. (in the sample below, we selected the microSD card)
alt="Image">
8. Click Convert to covert the files.
alt="Image">
9. Once the files are converted it's automatically transferred to the device or microSD.
10. Click OK when finished.
Mar 13, 2015 | Sansa Audio Players & Recorders
Card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 10, 2014 | SanDisk 8GB microSD High Capacity...
Pny sdhc card protected
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab. Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
Nov 23, 2013 | PNY 4GB Secure Digital High Capacity...
Media card inserted has errors to correct use a disk error checking computer
It could be the problem of file system of your media card. Disk check utility help to resolve that by sacnning the defected memory area and blocks.
Step to Do it:
1) Insert the media card into media card reader.
2) Confirm that u can see the device at My Computer
3) Note down the drive name for this device like C: or D: or E:
4) Type command in RUN ( cmd) and press enter
5) It will take you to windows command prompt
6) type the command( chkdsk /f <drive letter for exmaple C: or D: or E:) which belong to device in my computer
7) and press enter
8) It will scan and fix the file system error
9) Once it is finished remove the media card from card reader and reinsert it again
HOPE it works now
Sep 17, 2009 | PNY 2GB microSD Memory Card
Getting music onto my pny micro sd 2gb
You should just have to locate it in "my computer" open it up and drag and drop music files onto it. or just burn them on to it. e.g windows media player. if it wont let you. make sure its not locked by checking the switch on the side. Also ask your friend if he set a pin/password for this micro sd.
Jan 22, 2009 | PNY 2GB microSD Memory Card
Samsung MP3 Model YP-K3J QR
I went back to my Napster account and downloaded the music to a cd. I then downloaded the cd to my Samsung Media player and deleted the locked music. Now everything plays. I also discovered that some of my own CDs had locked when I transferred the music to my new computer so I just reloaded them on my computer and deleted the locked cds.
Thanks for checking.
Nov 09, 2008 | Audio Players & Recorders
Screen locked on "Checking media"
When the radio locks up on the Checking Media page you hold the + button to the volume and the MODE button wait for 3 seconds and it will turn off...  Thanks to Delphi for this assistance!!  Chris K.
Jun 02, 2008 | Delphi SKYFi3 XM Radio Receiver
Playing songs on my micro SD card
Not possible with this unit - it can only read the internal memory of the SD card directly
Apr 24, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa View 8GB = would not connect
I jsut purchased an 8GB sansa view mp3 and I downloaded it like I was suppose to and it does not work in Rhapsody at all, also in the windows media player it shows that the device was installed correctly but it still doesn't work and I still can't sync my songs to it. The sansa icon won't even show up
Dec 26, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Delphi SKYFi3 XM Radio Receiver Logo
309 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
