Question about Linksys Wireless-G WRT54G Router
Losing internet access every few minutes. Time Warner says problem is not theirs. I disconnected router for 30 seconds and plugged it back in but problem persists.
  • 550 Answers
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Click here for step by step instructions.
Posted on Oct 01, 2010
Recently installed a Nethear N150 router computer now switching itself off
Reboot or reset the router....
  • Switch off all the devices modem, router and computers also unplug their power cables.
  • Wait at least 30 seconds.
  • Plug the power cords back in, but don't switch them on.
  • First turn on the modem and then wait for a few minutes for it to settle and all the lights to become stable.
  • Next switch on the router (if a seperate device ) and then wait for a few minutes for it to settle and all the lights to become stable.
  • Now turn on your computer, You should now be able to access the Internet.
Here is the simple example :how to reboot the netgear router
Sep 12, 2012 | Computers & Internet
Internet connection lost every 30 minutes
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
May 22, 2012 | D-Link Xtreme N DIR-655 Wireless Router
Linksys WRT300N router flashing all lights
On the back of the router you will see what looks like a pin hole, turn the router on and use a paperclip to push into the hole(it's a reset button) and keep it pushed in till the router cycles off then on again, it resets the router to default. Hope this helps.
Jul 01, 2017 | Linksys WRT Computers & Internet
Why will my walmart.com not go through I switched to warner cable instead of att and put va router on and can not get my walmart associates log in to go through
Without knowing your network setup, I can list a few general ideas.
First, try powering off your Cable modem and disconnect all cables to it and unplug it for about 1 minute. Then reconnect the power. After about 30 seconds, reconnect the coaxial cable (thick black round cable with the wire sticking out) and screw it on tight. After about 30 seconds, reconnect the network cable from your cable modem to your router uplink port (if it has one...some newer routers have automatic uplink detection).
If that doesn't fix it, you make have to call tech support at Time Warner so they can register your equipment in their system.
Apr 13, 2011 | Microsoft Windows Vista Ultimate Edition
When I hook up my Dell2350 router to my westell dsl modem i can not access internet with my desk top or my laptop. When i disconnect the router I can access internet through dsl for desktop with no...
You will need to check the settings of the router. You are able to go online when you connect the computer directly to the modem. Your internet service provider is DSL. You can try to reconfigure the router. Press the reset button on the router for 30 seconds. release it. unplug the power to the router. plug it back in. wait for 1 minute and try to reconfigure the router. Click Here for step by step set up
Nov 18, 2009 | Computers & Internet
Constantly disconnects from internet and have to reset it every fiew minutes
This is a common problem. There are two ways on how to fix this. First, update the firmware of your router. You can download the firmware from D-Link http://www.dlink.com/support/
Before you install the router's firmware, you must do a hard reset. Press the reset button at the back of the router for 30 seconds then unplug the power for another 30 seconds before you plug it back in.
Access the router's admin page through http://192.168.0.1 and look for firmware update settings.
After successfully updating the firmware, you must do a hard reset again. Reset for 30 seconds then power cycle it.
2nd
If you are just referring to wireless connection that keeps on disconnecting, you'll just need to change the wireless channel on the router's admin page. Access the router's admin page through http://192.168.0.1 and look for wireless tab, change the channel to 11 and save the settings. If you have cordless phone you need to relocate its base away from the router.
Contact your ISP if none of the solutions work. Good luck and have a nice day!
Aug 05, 2009 | D-Link DIR-615 Wireless Router
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Losing connection with WGR614 v6 router
Well, glad I found someone with the same problem, the answer will certianly surprise you.
The answer is cordless phones and satellite interent.
if you have cordless phones and/or satellite internet it will lose signal.
They run on the same frequency.
To fix it log into your router, goto wireless settings, then check the box for enable channel settings. You may have to reboot the router and PC.
Should help.
Good luck and have a happy new year.
Dec 27, 2007 | NetGear WGR614 Wireless Router
Constantly losing connection
A wireless router if set at enable DHCP will always asign an IP address to each pc, and keep it, it will not alter until the next time your connected, and even if the first pc that you connected with, first next time, it will get the same ip address allocation. The solution may be that your router is set to disconnect from the internet after a period of innactivity. Go into router settings and look for something similair to (Idle connection-Never).
Jan 06, 2007 | NetGear MR814 Wireless Router
Linksys Wireless-G WRT54G Router Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
