Question about KitchenAid KSSC48QKS Side by Side Refrigerator
Water leaking from inside freezer door onto floor model kssc48qks01
    Sergeant:
    Champion:
  • 351 Answers
Most likely the drain is stopped up and that is defrost your seeing
Posted on Oct 01, 2010
Water leaking from inside of freezer bottom
Check the defrost of the freezer which you are using right now.For More information please visit Clothes Dryer Element.
Oct 06, 2012 | Hotpoint HSS25GFP Side by Side...
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Hi, have have 21' Bottom Freezer refrigerator, model 69142992. My bottom freezer is getting a sheet of ice on the bottom, where the basket becomes frozen in place. The the freezer leaks water onto the...
hi dear you have to unplug ur ridge and then open the freezer door remove the food try to defrost the ice by a hair dryer then remove the basket boil some water and pour it on the white metal back inside the freezer tell you feel the water goes inside ,your problem is drain blockage ,or stop the fridge for 24hours and it will work normally
Sep 11, 2010 | Kenmore Refrigerators
Water is slowly dripping onto the floor from the bottom of the freezer door. it is as if the door is full of water. any suggestions?
ARe the temperatures good inside the freezer? If they are not near 0° F, that is the cause of the water drip.
If it is nice and cold in freezer, check freezer floor, is there a sheet of ice? you have a clogged defrost drain, clear it or have it cleared for you.
Good temps no ice on freezer floor? possible water leak inside door from water dispenser
Aug 13, 2010 | GE GSH25JFR Side by Side Refrigerator
Maytag side be side model msd2454gr
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water runs out of freezer door overnight ,at times
Have a look at this link:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7670-leaks-water-floor-front-freezer.html
or this one:
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Apr 17, 2009 | Westinghouse Refrigerators
MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
KitchenAid KSSC48QKS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
