Question about Kenmore Washing Machines
I'm working on a kenmore front loading washer m/n 417.43142200 s/n XC33801994. When I take off the back & turn the belt by hand there's a clunking noise coming from inside the tub.
    Sergeant:
    Champion:
  • 351 Answers
The tub support on back of tub is broken big money part
Posted on Oct 01, 2010
Tip
Drive Belt Installation on a Whirlpool Front Loading Washer
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
on Dec 10, 2009 | Washing Machines
Tip
Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
I am trying to replace the drive belt on my Kenmore front load washer, model 41747102700. The old belt just fell off and was laying on the floor of the washer. In attempting to replace it it seems as if...
The belts on front load washers are very tight. The trick to putting them on is starting the motor side first. Wrap your belt around the motor shaft then while keeping your fingers there to hold it in place, use your other hand to start pushing the belt on the larger pulley while you turn it. The belt is going to try and work back off the motor pulley while you are turning the large pulley which is why you have to keep your fingers down there to hold it on. The new belt will have several grooves on it. Make sure these grooves are all meshed in the motor pulley grooves.
Jun 17, 2008 | Washing Machines
Kenmore front load washer 44052
Mine issue was a loose connection. I removed the back panel and pushed in all the wires. The washer started working again. If you take off the back panel and the belt is broken then that could be your problem. Unplug the washer first.
May 22, 2008 | Kenmore 44042 Front Load Washer
Spins very slow on rinse/drain and spin
Your filter &/or pump could be blocked. Remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter & clean out. Refit. If you have manual refer to it. Pl rate me if helped.
Jan 20, 2008 | Kenmore 46462 Front Load Washer
Kenmore 3.1 capacity front load washer
CHECK REAR BEARING(rear of drum)OR THE ROLLERS THE DRUM ROTATE ON LOWER PART OF WAShER
Jan 19, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
56 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
