Question about Vacuums
Oreck XL21 just will not work at all any more. Beater is clean - belt is fine. Fresh bag - inflates. Took the thing apart - checked for blockages at intake, bag entry, and the tube. It just doesn't vacuum anything. No suction at all for anything stronger than air. I'd say it doesn't ****, but that would be ironic. Are these known for just "quitting" after a while? We take it in for maintenance as recommended to replace filters, etc. Is there some miracle trick to make it work or should I just decide it's garbage now?
  • 377 Answers
Did you make sure the brush turns freely? Even though it is clean, if it does not turn freely with the belt, it will not beat the carpet and pull debris up into the unit.
Another (drastic?) thing to try would be to take the unit outside into your driveway and using a small source of smoke, a cigarette, etc, let the vacuum **** up the smoke and see if it exits anywhere other than through the bag. If it does, there is obviously a leak someplace in the unit that needs to be fixed.
Posted on Oct 01, 2010
How to replace the belt on an oreck XL21 vacuum
There's a Pannell on the side onevno2 philips head screw remove that and there is the belt
May 12, 2014 | Oreck XL21 Bagged Upright Vacuum
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Doesn't pick up
This could be a few reasons. Check and make sure your bag is not full of dirt, a full bag will make your vacuum's suction worse. Next check for clogs of dirt and debris. Check the nozzle and brushroll too. If you find no clogs and the brushroll and belt look good, it may be your vacuum fan is damaged and needs to be replaced.
Genuine Oreck Mataxalloy Fan Impeller R0008
GoodVac.com
800-775-6586
May 09, 2012 | Oreck XL21 Bagged Upright Vacuum
My vacuum seems to be just pushing around things instead of sucking them up. I changed the bag and cleaned the bottom, but nothing helped.
Did you check to see if the drive belt for the beater brush was broken or frozen up? The beater brush hits the carpeting and causes the dirt, etc, to jump into the air so the suction of the unit can pull it into the vacuum. The beater brush will be fairly easy to remove. Once it is out of the machine, clean it as best you can, add some WD40 on the plastic end pieces and when you reassemble, put a new drive belt on. This should solve the problem. Paul
Oct 11, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Simply won't turn on!
I believe all Oreck vacuums have a lifetime warranty. You should pursue that.
Mar 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
Oreck Commercial XL 21
Check that the beater bar is completely clear of thread, this will bring the brush roll back to normal. Also check the sides of the brush roll doesn't have anything such as thread or thick string at the sides.
Jun 16, 2009 | Oreck XL21 Bagged Upright Vacuum
Burning smell and not picking up
check for blockabe in bag inlet area, or bottom of unit by intake pivot.
ez check is to feel if bag blows firmly up with air when on, if not, you have a blockage.
Nov 02, 2008 | Oreck XL21 Bagged Upright Vacuum
Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Sep 07, 2007 | Vacuums
Oreck XL21
What does the belt tension feel like? Is it possible that the new belt you fitted is a bit too long (and starts to slip as soon as it encounters any real resistance). Any more methodical diagnosis is going to depend on observing which bits of the machine are still moving, and which aren't when the brush roll is stuck. Gather this information with caution, as it's a good way to lose a couple of fingertips. A.
May 17, 2007 | Oreck XL21 Bagged Upright Vacuum
Vacuums Logo
78 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
