Question about Westinghouse SK-26H590D Television
Westinghouse Model No: SK-26H590D TV will not turn on at all. I pulled back cover off and found the power board right by where the power plug goes in. There is a Fuse there and the fuse checks good with an Ohm meter and has continuity. I took the power board out and looked for any burn marks but did not see any. Any other ideas, or do you know how much that power board is and where I could get one? The board has this on it "WEAB71132269" in 1 row, then "P/N 4900254680" in another row.
baccardo
  • 150 Answers
SOURCE: I accidentally tried to insert a dvd in a
simply remove the top cover and get the cd out
Posted on Apr 16, 2009
  • 5 Answers
SOURCE: westinghouse sk-32h590d wont turn on ????????
is ur tv under 5 years old and u live in the uk phone the manufactorer and tell them about it if they give u rubbish about warrinty tell them about the sale of goods act for a tv it states a tv shold be reasonabley durable and of good quality for around 5 years if no anwser phone trading standards
Posted on Sep 24, 2009
westytech
  • 120 Answers
SOURCE: When I turn on my Westinghouse SK-26H590D with the
This one might be a settings issue but I need more information to help you resolve this issue, please send me a bit more details or your contact information at westytech@wde.com so I can better assist you with this issue.
Posted on Feb 04, 2010
SOURCE: Westinghouse tv Mod.SK-32H240S COMES ON SHOWS THE
Having the same problem and wondering if this solution worked :D
Posted on May 18, 2010
  • 11800 Answers
SOURCE: My Westinghouse SK-26H590D widescreen dvd combo
Most likely the laser lens was damaged when the 2 disks were jammed in. You must open the tv and check the status of the laser head and its lens, if it's faulty it will have to be replaced. Fortunately this is an unexpensive part.
Posted on Jun 05, 2010
Does sk-26h590d have HD connection
It might have a built-in HDTV tuner or it may require installation of an HD converter box. If you see decimal channels such as 3.1, 29.2, etc. you have an HDTV tuner. If you see channel numbers without decimals such as 3, 29, etc. you will need to install a converter box
Dec 27, 2012 | Westinghouse Electric SK-26H590D 26 in....
Owners manuel for westinghouse tv sk-26h590d
Hi Chuck,
You may download Westinghouse SK-26H590D User/Owner's Manual at this link (www.retrevo.com). When you are on the link, click "Download the Document", enter your email address and confirmation number, and then click "Download Now" to automatically begin the download. Manual is in Pdf file format, you must have an Adobe Reader to open the file. Just in case you don't have it yet, click this link to download and install it to your computer. After the download completed, run the set-up and then follow the wizard. The links I've provided are safe website, I used it personally.
Hope I helped you.
Have a nice day!
Kind Regards,
Jdvillanueva
Dec 19, 2011 | Westinghouse Televison & Video
About 8 months ago, every time I turned on the TV (SK-26H590D), only vertical lines would appears... almost like watercolor: green, orange, etc. However, you could hear the channels and change them as...
Hello
Get into Menu Operations and come to the window video reset. You can get this in its manual section [1-6]. Reset all video sub menu items to factory reset. Check out after this reset process whether the problem solves or not. If not its video card has some trouble. Contact
www.westinghousedigital.com and enquire them about the nearest westinghouse Authorised Service center of theirs to you. Thy only can set it right. OK.
May 08, 2011 | Westinghouse SK-26H590D Television
I have a westinghouse tv model number SK-32H240S the sound works but the picture dosen't if u turn the tv on the picture comes on for 1or2 seconds and goes out again
Hello Olga, this problem is normally caused by something on the power/inverter board (normally a transformer or a capacitor). If you are technical you can open up the TV and see what component is bad, you can normally tell because the component will leak or in the capacitors case be puffy. If you are not that technical you can also open the unit and simply pull all the plugs from the power/inverter board (big brown board on the left hand side when TV is facing down), take off all the screws, and replace the whole board. I can assist you with obtaining part #'s for this board if you would like just simply send me an email with the model #, serial # and TW # all located on the back of the TV as well as a brief explanation of what the TV is doing to westytech@westinghousedigital.com. Please rate my answer if it was helpful, have a great one.
Mar 28, 2011 | Westinghouse SK-32H240S Television
A dvd is stuck inside unpluged the tv and when i plugged it back in it wouldnt turn on
first off the dvd is stuck in the player, the tv will not come on it is a default that keeps you from messing the dvd player up, you need to take it to a repair shop,
you could mess it up if you try to clear it yourself.
Mar 03, 2011 | Westinghouse SK-26H590D Television
I have a westinghouse 32 tv
Hello, this model has a LIPS board which is a power board and an inverter board made in to a single board. What tends to happen when you have these symptoms is that one of your transformers has blown out. There are two ways of fixing this problem, one is to replace the whole board which is very simple, (Open back cover, unplug connectors, take off screws, place new board, connect, place screws, and place the back cover back on) or you can replace the transformer but this will take a bit more technical skills since you will have to solder the new one. The board can be found online in multiple places like www.shopjimmy.com, or you can call Westinghouse parts department at 1800-701-0680 and selecting option 2. If you would like further information or have any questions or concerns you can send me a quick email to westytech@westinghousedigital.com
Jun 05, 2010 | Westinghouse SK-32H240S Television
My Westinghouse SK-26H590D widescreen dvd combo won't play dvds.You can insert one but it will display "no disk".2 disks were jammed in the dvd slot and were removed(kids).I have a feeling it must have...
Jun 05, 2010 | Westinghouse SK-26H590D Television
This model has what are called a LIPS board in it which is a board that has both the power supply and the inverter on the same board. What you need to do is replace this part and your TV will be as good as new. To obtain this board simply email parts@wde.com and they will let you know price and availability of this board. Please make sure to include model#, serial#, and TW#, all located on the back of the unit.
Jan 19, 2010 | Westinghouse SK-32H240S Television
When I turn on my Westinghouse SK-26H590D with the remote it powers on I get a black screen with "VGA No signal" then after a few seconds it turns off and there is orange coloerd light instead of blue
Nov 12, 2009 | Westinghouse SK-26H590D Television
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
Televison & Video Logo
138 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
