Question about Century Portable Plasma Cutter 82021
I need a rectifier for my Century 90 amp wire feed mig welder (model 117-070). Where can I get one?
consaka
  • 661 Answers
SOURCE: machine is bump feeding the wire
That right there is how you know it needs replaced. Trust me I have one that is doing the same thing.
Posted on May 09, 2010
  • 81 Answers
SOURCE: difficulty changing the wire
check the tension on your drive rolls. Also check if the drive rolls are correct for that wire size.
Posted on Jul 01, 2010
  • 6 Answers
SOURCE: I have a century 155 mig welder and every time i
the electronic circuit is not working properly
Posted on Aug 16, 2010
eugbug
  • 479 Answers
SOURCE: We need to know how to get an owners manual for
This manual is available for download for $8 at:
http://www.centurytool.net/Century_82021_25_Amp_Plasma_Cutter_Owners_Guide_p/811-656-000.htm
Posted on Feb 15, 2011
  • 11 Answers
SOURCE: I have a Century 155 GL MIG welder, and it will
try the overload reset switch on the back of the unit
ensure the switch is not in purge mode or 0 on the temperature selection dial
ensure the temperature selection dial or rotary switch is fully engaged in the detent location,
not between temperature settings or numbers
check the pc board for a blown fuse
other temperature obvious component-s (fried)
check contractor switch components
Posted on Mar 06, 2011
Does anyone know where I can find a how to manual for a wire feed welder? The only info I have is Pow R Mate 90 amp 120 volt model number 117021. I think they were made by century welders.
There a hundreds of books published on the subject, if you live in the USA contact Hobart, lincoln, Esab, all publish books and manuals.
Nov 09, 2009 | Welding Tools
Need an operating manual for the century 80
Do a web search for lincolnelectric.com and look for the manual for this model.
Oct 12, 2009 | Lincoln Electric LE 83180 Century...
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Owners manual for a century wire feed 83160 mig welder
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Apr 19, 2009 | Lincoln Electric LE 83180 Century...
I have access to a century mig model 117-3-, 90 amp, 120 volt. the wire feed works and it welds, but it isn't getting 12 volt power to the feed. it might be the circuit board. i know the feed works...
yes its fixable,check the main contactor for proper voltage first,power boards are high dollar,so check the price of new one then decide if you want to put that type of money in the unit.
Feb 01, 2009 | Lincoln Electric LE 83180 Century...
Mig welder tripping power supply
the breaker could be bad. try to change the breaker
Dec 09, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Century Portable Plasma Cutter 82021 Logo
208 people viewed this question
Top Century Welding Tools Experts
John Trevino
Ted Maxwell
Tom Chichester
Are you a Century Welding Tool Expert? Answer questions, earn points and help others
