Question about Garden
Having trouble changing blade on a frejoth scroll saw... can't remove allen screws
  • 7 Answers
SOURCE: changing a miter saw blade
lefty-loosey (counter-clockwise). There will be space on the inside of the blade for another wrench to hold the shaft while you loosen the nut. If you've never done it, then you might want a pair of gloves; the blade might be dull on wood, but it'll be sharp on hands!
Posted on Aug 03, 2008
rowdy45176
  • 2176 Answers
SOURCE: Changing blade on Dremel scroll saw
I would suggest calling Dremel direct at 1-800-437-3635 and asking for tech help. You might also try their website at Dremel.com, but I have been there and you need to know the exact model number. Let me know and I will dig deeper.
Posted on Jan 17, 2009
SOURCE: how to change blade on bosch jigsaw GST 80 PBE
I just bought a used one and faced the same problem. What I found in there is a set screw at the bottom of the long shaft. I used a long narrow flat head screw driver. It worked good, but I did have to acuate the trigger to get it the blade near the top of the stroke
Hope that helps.
AG
Porsgrunn Norway
Posted on Aug 15, 2009
  • 10865 Answers
SOURCE: I bought a delta scroll saw model number 40-540,
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Posted on Sep 15, 2009
slave2aslave
  • 302 Answers
SOURCE: I have borrowed a Makita SJ401 scroll saw. How do
Scroll saws generally have to be loosened in two spots. One spot is above the blade near the tip of the arm. The other is generally below the plate. Most scroll saws come with a special tool that has an allen wrench type end accompanied by a round peg that is inserted just above or below the spot for the allen wrench.This peg type end helps to hold the tool in place and keeps the saw arm from moving around. The other end of the tool has a handle.
Hope this helps.
Posted on Nov 06, 2009
How to install the blade
There's Normally A screw on The Side or an allen wrench needs to be used to remove the blade !! But Make model Would Help Out Better !! We Are Here To Help !!
Donald Deane MCSE,ASE,CPO
Jul 27, 2017 | Blade Saws
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
How do I change the blade on model #17224 saber saw?
Are you talking about a reciprocating saw? What brand? If this is what you're referring to, then there is usually an Allen style set screw at the base of the blade. Loosen the set screw with an Allen wrench, and replace the blade. Retighten the set screw and cut away.
Oct 06, 2014 | Saws
I am having trouble inserting the blade properly
You press the lever forward all the way, insert the blade, and release. If the holder is getting worn it can be replaced as one complete assembly. Here is the user manual link. It shows how to use the holder.
Skil 9225 manual
The part number for the holder assembly is 2610938752. It is less then $10 and is held on with an allen screw so it's easy to change.
Jul 15, 2012 | Skil 9225-01 9.5 Amp Orbital Reciprocating...
How do i change my saw blade
Depending on the brand it will either have a quick release which you rotate to remove or it will use one or 2 small allen head grub screws to hold the blade in.
Mar 08, 2012 | Saws
Hope this helps.
Nov 06, 2009 | Plumbing
I have an old dremel 2 speed 16 inch scroll saw. The motor appears to work, but I can't figure out how to put a new blade in it! Can you help me?
a standard coping saw blade or a blade made for the saw - one end is clamped in the piston, the other end is clamped in the upper arm. look for an allen wrench set screw.
Oct 13, 2009 | Dremel Saws
I need to replace the blades on a Sears Scroll saw. Model # 149236160
Your scroll saw should have come with Hex end tools to use when changing out the blade. You must release the tension on the blade (located on top of arm above blade). There is a small allen head screw which has to be loosened with an allen wrench to release the blade. There is also an allen head screw under the working surface which will have to be loosened to remove blade at the bottom. Replace blade at the bottom 1st, tighten up then go to the top, tighten it, then reset the tension and you're ready to saw again. Make sure to get a visual on the directions of the blade teeth before you remove it so you can replace the new one the same way. I hope this is helpful.
Sep 26, 2009 | Craftsman Saws
How do I replace the blade?
Hi rq,
Look at the base of the blade, there is either a half twist quick disconnect or an allen screw.
Safety first: Unplug the saw.
If its the allen screw it will be located to one side of the blade. Just loosen it , pull the blade out.
The half twist ring doesa what its name implies. Twist it as far as you can (holding the saw with the bladed to the ground allows it to drop out) to free the blade.
Best reqards
Mike
Sep 11, 2009 | Porter Cable Variable Speed All-Purpose...
Change blade
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allen head screw that you must loosen or remove to take te blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in business.
Jan 18, 2009 | Saws
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
