Instructions for Whiterogers Thermostat model 2EMA3
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
Your best bet is to go here http://www.emersonclimate.com/en-US/products/thermostats/Pages/thermostats.aspx
Posted on Oct 01, 2010
How do you program a thermostat
Go to the honeywell website and look up the Installation Instructions for the model of the thermostat you installed. If you take the thermostat off its base plate the model number will be on the back of the thermostat housing. Down load the instructions. It will tell you the settings for all the mode of operation. Be aware to accurately put in the type of system you have initially when programming, because the the steps that are not applicable to your system will be passed over. Just change the values to the desired settings as you go over each function step.
Hope this helps.
Jul 24, 2014 | Honeywell Heating & Cooling
Where is the thermostat and how do i change it
Please see my tip at http://www.fixya.com/cars/r5929960-s_thermostat . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Your thermostat is here:
Nov 01, 2010 | 1996 Oldsmobile Cutlass Ciera
I have a carrier heat pump model # 38RQ034300 I need instructions for. To maintenance and use thermostst correctly
That is model number for your outdoor unit. Thermostats are not dedicated to any particular model outdoor unit. You need instructions for the thermostat so the thermostat make and model number are needed.
Oct 16, 2010 | Carrier Heating & Cooling
Do I have to drain the engine coolant on a 2005 Jeep Grand Cherokee to replace thermostat?
Yes, at least enough to be below the level of the thermostat. Heater on high when refilling, and wait for new thermostat to open, while filling...Pressure test when finished.
Oct 16, 2010 | 2005 Jeep Grand Cherokee
Diagram of thermastat 2000 chevy venture
  1. Remove the air cleaner intake duct.
  2. Partially drain the cooling system.
  3. Remove the radiator inlet hose from the thermostat housing.
  4. Remove the thermostat housing bolts.
  5. Remove the thermostat.
  6. Clean and inspect the thermostat housing gasket mating surfaces.
To install:
  1. Install the thermostat.
  2. Install the thermostat housing.
  3. Install the thermostat housing bolts and tighten to 18 ft. lbs. (25 Nm).
  4. Install the radiator inlet hose to the thermostat housing.
  5. Install the air cleaner intake duct.
  6. Fill the cooling system.
  7. Start the engine and check for leaks.
Oct 06, 2010 | Chevrolet Venture Cars & Trucks
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
I need instructions for wiring a Honeywell thermostat Model# 0924
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Apr 26, 2010 | Honeywell Programmable Thermostat Heater
How do i change my thermostat from celcious to ferenheight
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Hank
Oct 13, 2009 | Honeywell Programmable Thermostat Heater
Remote Thermostat Control hookup for AZ28E15DABM1
I called out an electrician and he wired it for me. Even told me they sold me one not designed for my model, but he retrofited it and it works fine. Been about a year now.
Jun 06, 2008 | GE Zoneline AZ38H12DAD Split System Air...
How do I wire up my fahrenheat F25408 baseboar heater?
Baseboard heaters are easy to hitch up. You can have a wall mounted thermostat or an integral thermostat. The diagram I have is for the integral thermostat. Follow the diagram and it should work.
Nov 28, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
