Question about Dryers
Model: 970-13600-10.Makes a lot of banging noises when running.Sounds like there is a pair of shoes in it.
4 Suggested Answers
JOE LLAMA
  • 26 Answers
SOURCE: LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Posted on Apr 04, 2008
TheMobilian
  • 8220 Answers
SOURCE: dryer makes a loud noise when drum turns
loose blower wheel
Posted on Dec 15, 2008
App King
  • 55 Answers
SOURCE: My Maytag model SDE 3606 AYW elec is making a lot
Hello.
Usually when a Maytag dryer makes a noise like that, the blower wheel is bad and will need to be replaced. This is a common problem and and a fairly easy repair. Take you model number to your local repair shop and they can get you the part and instructions on how to replace it.
Posted on Jul 24, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Why does Miele w2515 makes loud banging noise when it is about to spin?
See if you can level out the unit. Sound like the case is responding to un-even pressures.
May 23, 2014 | Washing Machines
Dryer makes a "thumping" sound even when it is running and clothes are not in it. Sounds like a pair of shoes are in there being dried.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 18, 2010 | LG DLE3777 Electric Dryer
My dryer makes noise when running
heatman101
hggf
Jan 18, 2010 | GE DHDVH52GFWW Gas Dryer
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Motorcycle is making noise from the transmission sounds like metal banging around, the noise comes a goes
You have a lot going on inside the transmission. Hard to say what the problem is from here but whatever it is you had best get it into the shop before the banging metal makes the trannie little more than scrap metal for the recycle bin..
Sep 21, 2009 | Harley Davidson FXDWG - FXDWGI Dyna Wide...
Drum on dryer makes loud noise when running - sounds like a clicking/banging noise? Model LDG8424ABE
sounds like some thing went through the drum or the bearing is worn out
Aug 29, 2009 | Dryers
Clunking noise every 5 seconds
You should check the compressor compartment and see if the fan motor (if it has one) is hitting something. Possibly a dead mouse?( I have seen this before) Also check if compressor mounts are secure. Hope this helps.
Jul 28, 2009 | GE Profile PSI23NCR Side by Side...
My Maytag model SDE 3606 AYW elec is making a lot of noise when it spins like its out of balance, it sounds like when you have a pair of tennis shoes in it
Hello.
Jul 23, 2009 | Dryers
HDA3400G020WW noise
dear sir the problem you have sounds like the solenoid that opens the drain actuater can be worn out open the bottom panel run tru a cycle observe when the solenoid open it may be that there is something causing the solenoid to buzz either worn out or a wire or something in the way causing not to close proprly thanks from gilles
Mar 10, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dryers Logo
65 people viewed this question
Top Dryers Experts
