Question about RCA 32V550T 32" TV
My tv keeps running through the input modes and won't stop.
    President:
  • RCA Master
  • 1,114 Answers
Check the button on the remote to see if it's stuck, as well as the button on the front of the TV. If it still has this problem, it's internal and needs to be serviced. Very very rare problem! Hope this helps.
Posted on Oct 01, 2010
I have logik l22fedr12 TV and it keeps going into scan mode and I can't stop it or use tv, how can I fix this?
When you say scan mode, is it scanning for input signals? I'd check the buttons on the tv and make sure the input button isn't stuck in the depressed mode as if someone was pressing it. I'd also take out the batteries from the remote to eliminate that device as a possible source to your problem.
Apr 15, 2015 | Televison & Video
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
Sylvania TV lc320ssx keeps switching input modes and won't and cannot stop it. Won't respond to remote or on set controls
Its main system control memory IC is faulty. Replace it. It can be located very near to the main system control IC. Will look like this.5328cc98-0a90-4a81-8aa5-f9c8c2b31484.jpgVery cheap to buy, easly available.
Can't get the tv to switch from cable to antenna mode using a RadioShack remote or the buttons on tv
It sounds that the front panel controls are locked with your tV. You have to unlock it first, if you want to change its input selections. If you cannot select the inputs by using the remote control [I thing you are using a universal remote control], setup the remote control with an other setup code. All codes to remote control won't work with some functions. You have to search and select, which code give maximum functionality with your TV.
Jul 06, 2012 | Zenith SY2569X TV
TV power comes on but then I just get a blinking green light. No picture or sound.
Make sure your cable input is in properly. The TV might be going into a sleep mode if it not getting an input signal
Apr 03, 2012 | Philips Televison & Video
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
I ve Sony Bravia KDL55EX713 55" TV, it keep showing me input banner showing(Bravia,LED,presence sensor,Motion flow,Full HD, BE3, WIFI HDMI etc.) I have tried display button, and all settings on...
Your TV is in store demo mode.
To fix this, access the TV's menu and find the option to run initial setup. At the beginning of initial set-up, you'll be asked whether or not the TV should be put into Home or Retail mode. Choose Home.
Mar 15, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
Feb 08, 2009 | Denon AVR-587
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
RCA 32V550T 32" TV Logo
64 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
