Question about Samsung TXR2675WH TV
HDMI input on this set looks like a serial port (pin holes and a screw-doen on either side). How can I utilize this with a standard HDMI cable?
    President:
  • Samsung Master
  • 1,114 Answers
The Input is Called DVI. If you are connecting to it with HDMI, you just need a HDMI to DVI adapter. They are sold just about anywhere TV's are sold. Roughly $30.00. Hope this helps.
Posted on Oct 01, 2010
How do i connect a monitor to acer aspire base unit
Acer Aspire One external monitor setup
Click the link and it will show you a youtube video on how to set it up. or view it below.
Tami
I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
Mar 03, 2015 | Acer Aspire Computers & Internet
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
How do i connect xfinity to my plasma display
If you're referring to your xfinity tv receiver (the cable box) there's a few different ways. Please keep in mind without much information, it's difficult to give a 100% direct answer.
There are four ways to connect it. We'll start with what will give you the best video quality, going to the worst.
HDMI cable: A single cable with a flat end. Your TV and receiver will have port labeled "HDMI". You plug it in, and then use your tv remote to set it to the HDMI channel. You may have source or input button on the remote. Press that, and a list of options will appear on your tv. Select HDMI. If there is more than one HDMI (as in HDMI1, HDMI2) try each one until you get a picture.
Component cable: A cable with 5 ends. They're color coded, so match up the colors. Then try that input our source button to select the COMPONENT option on your tv.
RCA cable: A cable with three ends. Color coded. Follow the same directions as above in regards to the correct "channel" to put it on.
Coax: A single cable, an end that screws in. Its connector will look like something can be screwed on it, with a hole in the middle for the pin to go into. Connect it, then tune your tv to channel 3 or 4.
Mar 30, 2013 | Comcast XFINITY
32 flat panel trutech how to hook it up to a cable box
Not knowing the exact model, there are usually several ways to get the tv signal to the set. There is an HDMI port - a "flat squashed connector", S-Video(round connector with 5-9 pins) + L/R Audio (2 small barrels one red one white) and the RF Antenna Input (looks like a fat bolt sticking out of the set) - this is what you would attach to your cable (the connector screws on)
Sep 17, 2011 | TruTech Televison & Video
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
May 12, 2011 | HP Pavilion m7570n (EX331AA) PC Desktop
Cant connect laptop to tv
Hey
If you're using a newer laptop look for either a HDMI (looks like elongated USB port) port or a DVI (a female port similar to a serial port but wider. Usually a white) port on the back/sides of your laptop.
If it's an older one, Look for an SD port (Resembles a PS/2 port which you plug the mouse in).
That being said, your TV must be able to pair with one of the above ports.
HDMI -> HDMI (using a HDMI cable)
DVI -> DVI
SD cable usually splits into three, Red, Yellow and White pins. Two for the LEFT and RIGHT audio channel and the other is for the video.
You might also be able to find converters from one format to another.
Hope this helps.
Cheers!
Dec 19, 2010 | Computers & Internet
Trying to connect a USB to the serial port of a Bernina Sewing Machine (Bernina 170). Has been working for a couple of years and has stopped all of a sudden. Does not work on and XP PC, Vista or win 7....
The Dynex adapter does not have any numbers on it. It was the one that is only about a foot in length and has a square center piece that houses the conversion electronics. Standard 9 pin RS-232 male plug on one end and the standard USB plug on the other end. I purchased it within the last month at BestBuy here in Austin TX.
Oct 28, 2010 | Bernina Artista 170
I'm trying to use my bravia as a computer monitor.
Your Bravia should have a 15 pin PC input, this input can take most standard PC resolutions, however if you a have a video card with an HDMI port, you should set your resolution to 1920 x 1080 @ 60Hz refresh rate so that the signal can be recognized and processed, many standard PC video resolutions are not compatible with the HDMI inputs. You should not require audio cables unless you are using a DVI to HDMI connection.
Crampy
Dec 11, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
EPSON PHOTO PC 500 DIGITAL CAMERA
Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
The stereo plug is wired to the PC serial port as shown in the following diagram:
tip ring sleeve +---------------------------------+
| RxD | Gnd | TxD | 2.5 mm Stero Plug |
DB9*: pin 2 pin 5 pin 3 +---------------------------------+
DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
pin 7 (RTS) to pin 8 (CTS)
The following table also describes the camera cable's wiring: Camera PC's
Plug DB9* Signal Name Direction
- 1 Carrier detect (CD) input to PC
tip 2 Receive data (RxD) input to PC
sleeve 3 Transmit data (TxD) output from PC
- 4 \ Data terminal ready (DTR) output from PC
ring 5 | Signal ground (Gnd) -
- 6 / Data set ready (DSR) input to PC
- 7 \ Request to send (RTS) output from PC
- 8 / Clear to send (CTS) input to PC
- 9 Ring indicator (RI) input to PC
* Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
Feb 22, 2008 | Epson PhotoPC 500 Digital Camera
Samsung TXR2675WH TV Logo
82 people viewed this question
Jerry Greenberg
Jerry Greenberg
