Question about Sharp XV-Z12000/ XV-Z12000U Projector (Brand ,Factory Sealed), Multimedia Projector
On my XV-Z12000, the red blinking lamp light came on. I turned off and on 4 times. Now the projector will not come back on. I have pulled the lamp out and back in and was going to reset the lamp timer. How can I get the machine to come out of standby?
SOURCE: Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Posted on Jan 10, 2009
projdoc
  • 2237 Answers
SOURCE: SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
Posted on Jan 12, 2010
SOURCE: Resetting the lamp timer to zero
some times the lamp cover switch is broken or not setby the cover ,this wil shut off power on button
Posted on Sep 26, 2010
  • 1833 Answers
SOURCE: Hi i just replaced the
I understand your problem. If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise.
check those first if everything ok
then may be the circuit have some problem, go to the nearest sharp authorize service center. or visit website
Posted on Jan 14, 2011
tech4allmen
  • 666 Answers
SOURCE: I have a Sharp xv-z9000u projector. I recently
While pressing down arrow, right arrow and ENTER on the projector, press POWER ON on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset
Posted on Jun 04, 2011
Hello i have a sharp projector model xv-z21000 my
mainboard is not work ,it need to be repaired
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Oct 14, 2013 | Sharp XV-Z21000 DLP Projector
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Bulb popped after replacement
100% Original lamp for XV12000
USD150
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jerry
Lampdeng Limited
Sep 06, 2013 | Sharp BQC-XVZ100005 Projector Lamp for...
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
I am replacing the bulb on my sharp xv-z2000 projector. i replaced it fine but the power light and the bulb light both stay red and i cant even turn the projector on. how do you reset the projector?
Two red lights indicate a problem with the lamp circuitry, i.e. the ballast. This requires a service center to change out a circuit board. Given the cost, it might be time to look for a new projector.
Dec 04, 2010 | Sharp XV-Z2000 Multimedia Projector
XV-H37U projector. Red power light is on when
reset the lamp timer. it's usually hold menu button , down arrow, and enter, and press power. but it's an old projector and may be different.
Nov 29, 2009 | Sharp Office Equipment & Supplies
Blue instead of red colour afer replacing lamp in sharp xv-z2000
You didn't put your 3-D glasses on backwards, did you? :)
Seriously, if you are using the component inputs, be sure the three cables didn't get mixed up when you put the projector back. Otherwise, you might have an issue with the color wheel inside the projector, but I doubt it.
Dec 31, 2008 | Sharp XV-Z2000 Multimedia Projector
Won't piwer on
Tried to turn it on? Sounds like you need to replace the lamp. However, I got an additional week out of my unit. Although poorly dimmed and the red Lamp light blinked constantly for that one week, at least it gave me enough warning to seek out a replacement. But so long as you're not mistaking the Power/Standby or Timer light for the Lamp light then I would have to agree with you. http://store.l-f-l.com/prod/A-1606-034-B Includes shipping to the United States and no sales tax outside of California.
Aug 16, 2007 | Sony XL-2100U Projector Lamp for...
Sharp XV-Z12000/ XV-Z12000U Projector (Brand ,Factory Sealed), Multimedia Projector Logo
47 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
