Question about Maytag PYE2300AY Electric Dryer
Dryer won't turn on. Circuit breaker is OK. Model PYE2300AYE
    Sergeant:
    Champion:
  • 351 Answers
High temperature safety thermostat
Posted on Oct 01, 2010
Neptune dryer has power but will not spin.I hear a faint click comming from the left side. model#MDE9700AYM
An electric Neptune clothes dryer, like most electric clothes dryers, has two circuit breakers: one for the drum and another for the heating element. Both breakers need to be in the "on" position for it to run properly. Go to your main circuit box. Reset both of the dryer's circuit breakers to the "on" position. If one of the breakers trips again, there's a problem with the dryer component that it operates. Contact a dryer repair technician to evaluate the machine's condition.
The lid switch is a small latch located on the interior of the door frame on your Neptune clothes dryer. It keeps the door securely shut when the dryer's on to prevent injury should you open the door and reach inside while it's turning. If the lid switch becomes damaged, the dryer won't turn on even though its lights might work. Run your finger over the lid switch and listen for a clicking sound. If you don't hear a sound when the latch is compressed, it's faulty and needs to be swapped out.
The thermal cut-off is a heat-sensitive safety feature on a Neptune clothes dryer that shuts off the heating element if the dryer overheats. After it activates, it can't be reset; you must replace it. Until it's replaced, your dryer might only partially function, so while its lights might turn on, the dryer might not spin or heat. Don't exchange an old thermal cut-off for a new one until you first determine what promoted it to trip, otherwise your dryer likely will overheat again.
Oct 19, 2012 | Dryers
Dryer won't restart breakers ok door switch funtional but when i press srart button just buzzes......... suggestions?
Reach inside and try to turn the drum. If it is stiff you could have a bad roller or support bearing depending on your model. I have all kinds of dryer manuals HERE
and Here
Jul 07, 2012 | Dryers
Maytag cloths dryer won't heat
A ground or a short is the only thing that could cause that sort of thing, unless you have a strong electrical background I would call a service technician for this
Jun 19, 2012 | Maytag Dryers
My general electric heavy duty automatic electric dryer won't heat. Is there anything to try before replacing heater?
go to your fuse box and try replacing the 2 fuses for the dryer circuit or if you have a circuit breaker box shut off the breaker for the dryer and turn it back on and try the dryer again. I used to be an electrician and found double pole circuit breakers that have only one side tripped. alot of 220volt electric dryers use one circuit for the tumbler motor and the other circuit for the heating element
May 07, 2012 | GE Dryers
Have a GE Dryer model DCL333EAOWW that will not turn on. Circuit breaker to wall outlet fine. Thought it might be switch behind 1/4 turn knob you use to turn it on. Replaced switch. Still won't start....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | GE DCL333EA Dryer
I have an Oasis elite electric dryer model #110.6706 and I do not have heat even the drum is turning.I allready read in the troubleshooting book about fuses or breakers.I check the breakers but I can not...
if you have circuit breakers in your panel, you won't have fuses also, if you have turned the one controlling the dryer completely off and back on again, thats fine, what your going to have is a burned element on the heating coil,
Jul 15, 2011 | Kenmore 67082 Electric Dryer
All of a sudden dryer won't come on. Checked connection, OK.
Check your circuit breakers. Your unit usually has a double circuit breaker. Find the correct circuit breaker and turn it to the off position to reset it then turn it back on.
Good luck
Sep 29, 2010 | LG DLE2532W Electric Dryer
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
