Question about Craftsman Garden
Have a hydrostatic sluggish tranny on a 15.5 kohler, model 917252590. New belt, how do change tranny fluid?? And with what fluid?
4 Suggested Answers
  • 95 Answers
SOURCE: craftsman 15.5hp 42'' changed hydrostatic fluid
Purge the transaxle by pulling the freewheel lever at the back of the transaxle.With the lever in the freewheel position run the engine full speed with clutch out,work the forward/reverse control back and forth 10 times and then try it.Also make sure that if you had the wheels of that you didn't lose a wheel key.
Posted on Aug 16, 2009
Testimonial: "Tried what you said now at least the wheels do turn a little. Gonna let it sit and see if i can purge it some more."
  • 396 Answers
SOURCE: My father owns a 1985-86 Wheelhorse Model 314-A
ususally it is the tensione just has to much give it will nbeed to be rreplaced
Posted on Oct 25, 2009
  • 1244 Answers
SOURCE: The hydrostatic transaxle on my Craftsman 20/46
you sheared a pin inside if the transaxle or shelled out the spider gears which does happen
Posted on Jan 20, 2010
I have a scotts riding mower 15 hp CV15s Kohler engine.. will not go uphill
Either a drive belt slipping or if hydrostatic bad springs or drive plate in transmission.
Sep 06, 2017 | HP Garden
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
Husqvarna hydrostatic transmission
my transmission on the right side do not have the power the lifr side have what do i need to do to fix it
May 14, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
I have Poulan Por 54 inch deck,25 hp Kohler hydrostatic. After I mow on unlevel ground for about 30 min. Transmission makes noise jerks and won't go till it cools off. Will changing the fluid help
couldn't hurt to try but some cheaper mowers don't have a drain plug look on a parts break down on sears parts online but check the belt tension first
Apr 13, 2012 | Garden
I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
Jul 21, 2010 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
L111 transmission slips
Is this a hydrostatic transmission if it is check the fluid level. It will really need changing and some are sealed and not to be worked on BUT it is possible to drill a hole in the bottom and top of a sealed unit to change that fluid just don't get any shaving in it. These transmissions must stay clean. The drilled holes must be taped and plugged now you can change that oil just like your car. Don't forget to purge that transmission. By the way they use 20W 50 motor oil.
Aug 25, 2009 | Garden
Craftsman 15.5hp 42'' changed hydrostatic fluid with mobile 1 synthetic 15w50 and now the wheels will not rotate at all. Checked everything belts on right pulley turning on top of tranny, disengage for...
Aug 15, 2009 | Craftsman Garden
Garden Logo
64 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
