Question about Craftsman 25cc Gas Line Trimmer
Craftsman 25cc weed eater carburetor need order of gasket and diaphram from the push bulb down
    President:
  • Craftsman Master
  • 1,545 Answers
You just need your model # . You don't have to buy the diaghragm kit you need from Sears. You will need to know the manufacturer of the caburetor. Then, the model # of the carb. Then you will have all you need to order a diaghram kit, and they are not expensive. They normally don't include the bulb, but it can be purchased separately. Or you CAN go the Sears route if you like. Go to www.searspartsdirect.com and type in your info to see if they have the carb kit and part you want.
Posted on Oct 02, 2010
My weed eater will run for about 3-5 seconds in the half choke position, but turns off every time. My instructions say to leave it running in the half choke position for about 10 seconds and then push it...
Carburetor. It is always the carburetor 90% of the time on these. There are gaskets and diaphragms in these little carburetors that go bad and periodically need to be replaced. The introduction of ethanol into our pump gas has only hastened this situation. Your carburetor is dying "lean" as they say, and is a result of lack of fuel flow through the idle jet and the high speed jet...probably due to a stiff fuel pump diaphragm and metering diaphragm. They sell a little bag with replacement parts to make it work right again. It is called a G & D kit (gasket and diaphragm). You HAVE to know the manufacturer and the model number of the carburetor to order the right one though.
Aug 13, 2011 | Craftsman 25cc Gas Line Trimmer
Trimmer not getting gas
carburetor diaphrams are stuck. clean the carb and check the diaphrams to see if they are stiff.
May 02, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Craftsman weed eater wont run
MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
Sep 24, 2009 | Garden
Craftsman Weed Eater only runs on choke (not at all now!)
Check the mounting screws holding the carburettor and the plate behiend the carb, they often become loose, also the gaskets, they might need renewing. Your carb. could need cleaning and new diaphrams. stephen.
Sep 20, 2009 | Craftsman 25cc Gas Line Trimmer
My weed eater will not start
Sounds like the carb or gasket around the carb is leaking allowing the pressure to blow by when you press the primer bulb. If its not air tight it will not pop back out. Check your carb and surrounding gaskets and check for a leak.
joe
Jun 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Craftsman 32cc weed eater wont start. Push in the primer bulb and it does not refill, stays stuck in!
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Craftsman 25cc Gas Line Trimmer
Need gas line routs for a craftsman weed eater
The longer, (and sometimes smaller of the two), fuel line goes from the carburetor to the tank with the fuel filter attached to the end, inside the gas tank.The other line, ( sometimes larger), goes from the primer bulb to just inside the gas tank, about a 1/2 -1 inch inside with coupling attached to the end. Coupling keeps line from pulling out of tank.
Jim
Jun 10, 2009 | Craftsman 25cc Gas Line Trimmer
Fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Apr 04, 2009 | Garden
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
Poulan Weed Eater GHT220
there are mntwo different size fuel lines which one does the gas filter hook up to?
Oct 17, 2008 | Poulan Ght225 25cc Gas Hedge Trimmer
Craftsman 25cc Gas Line Trimmer Logo
462 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
