Question about Apple iPhone 3G
My 3G iphone stopped charging anymore,it happened only once i just delayed the charging and the battery indicater displayed full drained.there is battery symbol indicating only red charging level and power symbol.please help.thanks
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 43 Answers
Possible battery problem, i suggest you visit the nearest service center for your phone to be check by a professional.. if it still under warranty much better so you dont have to pay any charge for the repair.
Posted on Oct 01, 2010
Iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
Feb 25, 2013 | Apple iPhone4 4G iPhone 4
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
I phone 3g not switched off and not started
This happens when your battery is totally drained. Leave the iPhone for charging for atleast 2 to 3 hours. If it still doesn't start, then perhaps you need to take to the iStore and get your battery replaced.
Feb 04, 2011 | Apple iPhone 3G
Hi Everyone, I have recently bought a new Iphone
Make sure that your WiFi is not left on all the time and that the signal is strong as weak signal affects the battery. Adjust the screen brightness to low and avoid using the phone for games etc to maximise battery life.
Oct 20, 2010 | Apple iPhone 3G
Dropped/jailbroken iPhone doesn't charge or restore
Try hooking it to itunes then hold the home and power buttons for 6 secs. then release the power button and keep holding the home button until itunes sees the phone then restore.
Aug 04, 2009 | Apple iPhone 3G Black Smartphone
Battery drain out in 2-3hrs just on standbymode!!!!!!!!!!
I would upgrade to the latest firmware, it seems it saves battery. Also, is your phone on full lightning, if so, put it lower. If it still does that, maybe you have killed your battery by recharging it too much, or leaving it on the charge too frequently. That kills the battery's life. If thats the case, you'll need to get a new battery from apple, and it's expensive.
Oct 07, 2008 | Apple iPhone 3G
How long do i charge the iPhone 3g before using it?
if it is a new one initial charge for 8 hours even if the battery is full...
after that you can try can stop after the charge is full
Sep 15, 2008 | Cell Phones
AFTER A FULL NITES CHARGE, AND USING MY IPHONE FOR ABOUT8 MINUTES OF CALL IN A DAY, MY IPHONE BATTERY IS DOWN TO ABOUT 1/2 CHARGE, AND SOON IT WILL NOT LET ME CALL OR RECEIVE ANYMORE. WOULD APPRECIATE...
first get a new battery and make sure you charge it fully and drain it completly 4 to 5 times befor you can charge it at any battery level.
Jul 29, 2008 | Cell Phones
Apple iPhone 3G Logo
128 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
