Question about Refrigerators
Refriderator side is nice and cold. Freezer side is hot 55 degrees. I have unplugged a couple of times but still won't lower the temp.
    New Friend:
  • 50 Answers
Did you replace the fan on your unit? its not possible that the fridge is colder than freezer unless the fan is reverse..
Posted on Oct 01, 2010
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
Fridge is freezing everything. Tried to unplug to reset, now front panel is blinking and won't do anything else. I have a rb215lash bottom freezer refriderator.
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Aug 25, 2011 | Samsung RB215LASH
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
GSS25KGPJWW side by side; refrigerator running almost constantly and my wife noticed that food in the "Fresh Produce" bin and the "Deli Fresh" bin was freezing. I now have the...
Try shutting the vent between the freezer and the produce bins, the freezer should be colder-down at least to 5 degrees, turn the freezer control to max cold and leave the fridge temp where you put it. the go from there
Jun 24, 2011 | GE Refrigerators
Keep a refrigerator/freezer in garage. The
Good day,
Yes. Domestic appliances will not work properly below approx 55 degrees.
The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower.
They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit.
The machine is not broken.
Moving it inside, is the only solution.
Thank for using Fixya
Jan 02, 2010 | Frigidaire Freezers
Side by side refrigerator in unheated space not working in cold
Good day,
GE recommends minimum ambient air temp above 55 degrees,
and that's pushing it.
Move it inside.
As an example. If the garage temperature was 10 degrees and the machine was left unplugged. What would the temp be in the fresh food section. If you said 10 degrees, you would be right.
P.S. Insulation does not prevent an area from getting cold, it just delays the time.
Nov 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Mr.
When the heater comes on for defrost behind the rear freezer panel , it gets red hot . The defrost thermostat ( bimetal ) , cuts the heater off , when it reaches 140 degrees for new (2000 - 2009 ) and 55 degrees for older refrigs . When this temp is reached at the top of the coils , the lower portion will be hotter due to being closer to the heater . The frozen food in the freezer , is what keeps the temp down in front of the rear freezer panel . No food in freezer , the hotter the freezer section will be .
Oct 03, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
May 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side freezer cold fridge not
the freezer may be overload or poor air circulation inside the freezer
Mar 10, 2009 | Kenmore Refrigerators
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
