Question about 2wire (2701HG-B) Wireless Router
My 2wire router 2701 HG-B drops the wireless connection when someone calls on the home hard wired line. Is there something wrong?
Your wall filters may be plugged in wrong. Verify they are plugged in correctly. This is likely the problem.
Posted on Nov 14, 2010
Can the 2701 HG-B handle 6000-plus Kbps?
According to the setup screen, it can handle DSL link speeds up to 10692kbps (down) and 1036kbps (up)
I can't verify that it works, but... that's what it says
Jan 02, 2013 | 2wire 2700HG-B Router (2700HGB)
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
How to configure 2wire 2701?
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
note: 2wire is already a wireless router / modem need for other modem to have a good network at home
if you are with At&T AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 11, 2011 | 2wire (2701HG-B) Wireless Router
I have this 2wire 2701 HG B wireless modem router. I have lost its manual. How can i access its settings to disable wireless router
you can ussually surf to the routers configuration page via its ip address
From a command prompt type IPCONFIG and the default gateways 'should" be the router's IP
Feb 04, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
Wireless light not lit
The wireless functionality of the router is no longer working. The light is always turned on on all wireless routers
regards
Sandeep
Nov 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Changing channel on router
hi....
to change wireless channel of your 2wire 2701hg youjust need to access its default gateway 192.168.1.254 type it on your address bar using internet explorer and you'll see network at a glance page. click on home networking tab at the top and look for subtab written in blue click wireless settings. you'll seewireless name and under that you'llsee wireless channel you just need to pick the channel that you want to use...
Sep 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Is the DWL-520 Wireless Adapter compatible with the 2701 HG modem
The 802.11b and 802.11g Wi-Fi networking standards are generally compatible. An 802.11b router / access point will work with 802.11g network adapters and vice versa.
There is no such conflict reported with the above devices. But as suggestion use an 802.11g wireless card with the Bell as it would give you better performance
Thanks for using Fixya
proton
Jul 27, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
I need information on how to configure my 2wire 2701 HG-B modem for wireless access
Log into your router. Click on home network. Status at a glance box, click on edit settings under wireless settings. Under setting click enable SSID and Wireless network security. Your WEP key is on the side of your router. The number above the second bar code with brackets around it.
Hope this helps you.
To log on to your router type the routers ip address into the address bar. If you don't know it....click start....run...type cmd press enter....type ipconfig /all at command prompt...press enter... look for default gateway address.... type that number into the address bar of your browser.
Jan 28, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire (2701HG-B) Wireless Router Logo
647 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
