Question about Whirlpool Duet GHW9150P Front Load Washer
Not working no taking water
  • Whirlpool Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Oct 01, 2010
Have a Rheem PTG-74PVP tankless water heater. Shuts off after a few minutes while taking a shower. Get a code 76 C8
Before calling service technician, open following links for troubleshoot resources including error codes and rheem chat, and typical scheduled maintenance:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Error 76 can mean communication failure between tankless and remote control, which can include bad remote control, bad wire, bad wiring connector, or PC board failure.
Disconnect remote control and see if tankless will work.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Error C8 76 can mean PC board failure.
Contact Rheem and/or service technician.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 07, 2011 | Rheem Tankless Hot Water Heater...
Basement was flooded and water cover electronics,
TURN OFF ELECTRICITY before touching gas or electric water heater this is or was flooded.
Replace flooded gas or electric water heater.
Warranty is void, all manufacturers say replace water heater, and even if parts are replaced, there is no guarantee that unit will work again.
Resources:
http://waterheatertimer.org/Flooded-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 01, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water and ice is not working , this is a new unit and no when i connected water line, water will not flow to ice maker and or water despensor, it sounds like its working and or trying but water will not...
Hi and welcome to FixYa, I am Kelly.
On a new unit if you did not purge the water supply line it will take quite a while before you see water in door. You have to fill the tank in the door and then you will eventually see water out the dispenser. Just hold the water in door arm depressed with a glass until you notice water coming out. It should not take more than 3 minutes of continuous actuation to see water though the door.
It can be 8 to 10 hours before you ever see any ice production and the first batch of cubes may be small. After the first batch they should be regular sized. The freezer has to reach between 14 - 16 deg F before the themostat in the ice-maker actuates the harvest cycle.
Let me know if this does not work. Please do not start taking things apart as your unit is under warranty you may VOID your warranty.
Thanks for choosing FixYa,
Kelly
Feb 16, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
We have a Rheem 50 gal water heater, model # 81MV52D B. Is there a way to test the heating elements to see if they are working properly?
1) You can test Rheem 4500 watt elements using steps on following link:
http://waterheatertimer.org/How-to-test-water-heater-element.html
2) Take 30 minutes and do complete troubleshoot
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) How electric water heater works
http://waterheatertimer.org/How-it-works.html
4) Add a comment for more free help.
5) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 16, 2011 | Rheem Water Heaters
Water not flowing out..the icemaker works fine, but when you select water, water does not flow out....what should I look at?
you can take a peice of weed eater line and stick through the water line in the door and see if it goes all the way through. If not then there is frozen water in the line.
if there is a coupler on the bottom of the door disconect it and try to dispence water if the water comes out there then the water valve is good and you need to defrost the line i the door a blowdryer usually works for this but it does take some time
Aug 31, 2010 | Hotpoint Refrigerators
The ice maker works, I poored water directly to the ice maker and it works, don't understand what you mean with alligator clips, should i just take the hose leading to ice maker off, the intake water valve...
Wrong! ok what it is you have a double water valve. 1 valve goes to the ice maker and one goes to the water dispensor. what you need to do is take the valve that goes to the ice maker by tracing the water line from ice maker to the valve and jump it direct with 110 volts. if you get water by doing that the ice maker is bad if you dont get no water that way it will be the water valve
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
The washer will not start to take water
make sure the water is turned on, and if it is check kinked hoses,
check clogged inlet screens at water valve, or replace water valve,
Apr 05, 2009 | Kenmore 22422 Top Load Washer
Bosch S9GT1B not taking water
check electro valve,water-level switch.
Feb 15, 2009 | Bosch Dishwashers
Bosch Exxcel MAXX dishwasher not taking any water
yes u got water on the bottom and there is a switch there first take the water from the bootom
Dec 29, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Machine stopped taking conditioner
Also, if the solution that you have above doesnt work, some model washers use a computer board to control the flow of water through the dispensers.  Not usually likely that they go bad, but they do.  If cleaning it like the first solution doesnt work, it may be a bad board, bad water control valve (the one that controls dispenser water), or bad timer.  Hope your first solution works for sure, usually does.
Oct 10, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
