The water level in my washing machine is too high. washing machine fills to top of washing machine on all three levels; low, medium and high.
  • Anonymous Mar 30, 2014
    to much water goes into the machine
    Sergeant:
    Champion:
  • 351 Answers
Water level control
Posted on Oct 01, 2010
After washing 2 loads the machine won't fill to high level it only fills 1/2 way
You have a faulty fill valve. Return/ replace you washer if under warranty. If not then you will have to replace your fill control valve. That valve is where the knob for the fill level is.
Mar 12, 2014 | Danby 1.7 Cu. Ft. 4-Cycle Portable...
Does not sense clothes
most top loaders fill to the setting you enter into the program l( medium low high etc ) as the clothes absorb the water it will keep filling until a level is reached at which point that is the amount of water for the clothes and the machine will start you just have to think about how many clothes you are washing and how big they are ie blanket will be a big load and nickers will be small load
Jun 09, 2013 | Washing Machines
The water level never stops, it just fills till it over flows
if on auto level select water level eg medium or low depending on amount of clothes this sometimes works dont use auto water level. If not check small pipe under touch board on top panel, make sure u unplug mains from plug pipe may be loose its small plastic goes to level sensor on right of board. If not level sensor faulty.
Feb 21, 2011 | Haier HLP21E Top Load Washer
I put a fairly large load in washer. As the washing started I needed to add an item. I was surprised that the machine had very little water in it. Is there a way to add more water. Also when soaking I had...
The Series 10 and 11 machines have three level fill points the Series 12 and above have two level fill points.
I know Bulky Items wash selection will give you a High water fill which is only 7 inches or so of water in the wash basket. 3.5 inches of water for a medium fill.
You can turn on/open the water inlet valves in Service Mode but I would not recommend that. A manual fill as you did is the only safe way to set the additional water level IMOP.
FAV6800A/FAV9800A Service Manual for reference.
Rich
Jul 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Do water level is not working. It will over flow
change your pessure switch. Thats the switch that says
medium low or high loads
Jun 06, 2010 | Kenmore 22422 Top Load Washer
Machine won't fill up. Water just keeps on running.Tried to fill up on low, medium and high to no avail.
Good day,
If it keeps filling, and can't then it sounds as if you have the drain hose positioned too low.
It must reach a point higher than the highest level the water will ever reach.
Jan 18, 2010 | Washing Machines
Maytag FAV6800AWW - Major overflow right after starting machine
Hi, If you turn the water source valve on and water starts filling the machine even tho the machine is off, change the inlet valve.
If you have to start the machine so water will fill but, the water does not shut off at the desired level, there is a problem with the water level switch.
I hope this helps you. Please let me know if I can assist you further.
Vic.
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Washer will not fill before agitation
The settings on water level may be set on very low amount. Check see your water level is set on medium or full. You may be expecting the wrong amount on the low setting.
Feb 18, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
