Question about Sony Handycam HDR-HC7 Mini DV Digital Camcorder
My Sony HC7 seems to record but the playback mode does not work. Also, the date and time feature goes back to 2007 everytime I power down. Bill
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on Oct 03, 2010
Testimonial: "I spilled water on my camcorder, and all functions did not work. I let it dry out. Each day some new feature returned, and all work fine now. "
Why i have to set clock after changing battery everytime
you need to change your settings to auto date and time update
Nov 24, 2011 | Sony Handycam HDR-HC7 Mini DV Digital...
I downloaded a .msf file from a Sony audio recorder. Please advice how I could playback this audio .msf file.
Hi!
It seems like you've downloaded the wrong files...
As mentioned at Sony's FAQ:
MSGLIST.MSF is a file that contains information such as the order of folders, playback order of audio files and recording date and time. If user connects the recorder to the computer, the MSGLIST.MSF files are displayed but do not delete or change these files. If these files are operated, the saved files may be broken or the recorder may not work correctly.
The right way to copy your recordings is explained here...
If you are satisfied, rate my solution with 4 "thumbs" or (even better) add a testimonial.
Good luck and Best regards,
Pelu.
Apr 29, 2011 | Sony Audio Players & Recorders
Need to get rid of date stamp on playback of videos...unfortunately videos have already been recorded...is there a way to turn it off on playback?
Well if you decided to date/time stamp on your films, then that is what it has done for you, just go into setting on menu and turn them off again, that is the default mode.
Jun 06, 2010 | Sony DCR-SR47 Camcorder
Panasonic PV-DV103 Playback Problem
check ur recording mode it may be on snapshotmode change it. or clean ur cam head
Jun 04, 2009 | Panasonic PV-DV103 Mini DV Digital...
HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Mar 07, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Fuji finepix f420 no live image/memory not storing data
seems as if you havent fully charged your battery not sure if im right about my solution but its worth checking
Feb 12, 2008 | Fuji FinePix F10 Digital Camera
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Aug 18, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam HDR-HC7 Mini DV Digital Camcorder Logo
224 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
