I am trying to boot up my pc and I just received STOP: 0X0000007E (0XC0000005, 0X82E89963, 0XF8AEF8B4, 0XF8AEF5B0
    President:
  • 3,278 Answers
Hello.
The most common reasons for these errors are memory and hard drive problems.
To determine further, run the diagnostics for your computer. It varies from computer to computer, but try pressing F12 when booting.. It may be different for your computer.
If no diagnostics results available, try your memory, first. Remove all memory and place one at a time and boot your computer to test. If no difference, your hard drive is probably failing.
If the hard drive is bad and you want to try to retrieve your files, set your hard drive as a slave and install in another computer. You may need on-site assistance with this.
Hope this helps.
Posted on Oct 01, 2010
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
Stop 0x0000007E (0xC0000005, 0x8A390AB3, 0xBA507B90, 0xBA50788C) i receive this when i start up my computer
Its the bsod (blue screen of death)
There is no way to sort this basically your computers doomed, you can get on your computer via safemode but not through normal windows sorry, i had the same problem with my old laptop
May 28, 2010 | Dell Inspiron 1501 PC Notebook
I have received a Blue Screen Error but I do NOT have the XP disk
if you cant get online on your pc you're gonna need to go to someone else's and download a windows boot disk from the ms website then boot your pc from that, choose recovery console then repair boot partition.
Feb 28, 2010 | Microsoft Windows XP Professional for PC
E-machine gets the blue screen that says.....stop 0x0000007E(0xC0000005, 0x8053A593) what does this mean
A registry error or device driver is causing this. Attempt a boot to safemode by tapping f8 after the computer boot logo screen and before the windows logo screen.
if you can't boot to safemode then try the same key sequence but select "last known good configuration". If this does not work, then you will have to repair reinstall the operating system.
if you can get in safemode or last known config, make sure to run a spyware/virus check if you didnt' install any programs, devices or used a registry cleaner like CCleaner
Feb 14, 2010 | E-Machines eMachines Desktop PC
Having a blue screen issue, boots to windows splash screen, then gives blue stop:0x0000007E error with various (0xc0000005,etc) variations after it. have tried to boot with a floppy, no go. will not let me...
Have you tried to boot in Safe mode? Well if not then press F8 as the PC starts and select safe mode. If it works, then select the 'system restore' option which will appear and restore the system to as far back as it worked very well. Your files will be intact. Well if safe mode those not work, then since you cannot change your boot order to boot from CD/DVD, then you would have to take out your hard drive and connect it to another PC and follow this tip of mine: http://www.fixya.com/support/r3766678-booting_bootable_windows_cd_dvd_fresh
All the best.
Jan 14, 2010 | Panasonic Toughbook 29 Touch (P/N...
Error code 53000:031e stop:0x0000007E COMPUTER WIIL NOT BOOT UP
hi there !
-boot to SAFE MODE
-restart the computer and press F8 and choose SAFE MODE then do the steps below
Windows Update Causing STOP Error 0x0000007E
-For now simple system restore should fix the issue, else uninstall this update by booting to safe mode.
-Uninstalling windows update KB973879 and hiding this update from available update is currently seem to be fixing the issue.
In case if removing update KB973879 doesn’t fix the issue, we need to remove remaining two updates KB970653 and KB972036.
cheers!
Oct 20, 2009 | Dell Latitude D510 Notebook
Balance - Blue Screen during shut down stop error 0X0000007E
check your hardware settings it could be the codes for the hardware that cannot recognize of your systems. it could be change with the wrong specs. if you cannor configure it out. you better set the bios configuration to default setting and try to repair the system using your operating system cd installer. thanks
May 11, 2009 | Computers & Internet
0x0000007e error code in acer motherboard of win
hi,
Some users experienced similar problems when SP2 was released, so this could be the problem. If the user sees a stop error code of 0x0000007e, this first issue is likely the reason why the computer does not boot properly.
The second issue will only occur on systems with certain acer motherboards. This error manifests itself with an error code of STOP: 0x000000A5. It is unknown how to fix this problem other than by installing a USB storage device, or even possibly removing a USB mouse and replacing it with a PS/2 port compatible version.
If that is not enough, Microsoft MVP Jesper Johansson reports that there seems to be a third, less common problem with SP3 computers, this time on Intel. Some may receive a 0x00000024 stop error, which he believes may be due to an issue with either the NTFS file system being corrupted, or a faulty video driver.
go to microsoft .com under solutions page and type in the information code error they have been working on a dowload patch to correct this . go there http://support.microsoft.com.
Mar 30, 2009 | Acer Computers & Internet
I received the following stop-error screen: "A problem has been detected and windows has been sut down to prevent damage to your computer." TECHNICAL INFORMATION: ***STOP: 0x0000007E (0xC0000005,...
You Need to reinstall the windows and clear all previous data from your computer and disassemble any new hardware if u attached with your board ok your problem will be solved OK best of luck .
Mar 07, 2009 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
