Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Response yes the problem with your method is that my computer doesn't recognize my samsung at all when i turn it on as i previously stated it goes to the song that was played previously. It is then completly frozen by the title and time.
  • 8,596 Answers
There is no problem with the method. Turn the Samsung off, hold in the volume + button, plug it into computer while holding the volume +, and continue holding the volume + button for up to a full minute. Windows will eventually pull up the Found Hardware Wizard, reload the needed drivers, and will recognize the Samsung again.
Posted on May 26, 2008
Windows does not hear tape sound from tape rec
Fix Driver Solution In Windows-Start-Control-Panel-Device Manager then search through the list for the element of distress. If it's Audio, it is in the Sound-Video-Game Controllers whereby left clicking on that section will open up a window indicating your electronic devices. A video Camera-Sound Source may show up and if you Right Click on that line you get a message Update Software? You will get another option the Search On-Line Note-you must have internet access for this feature- and say yes, and allow a search to ensue. If you have the Best Driver installed a message stating so will appear- if not you will get an updated driver and it will be installed for you automatically. The other method is to go to the Manufactures Web Site and Support area. Input the necessary data re Model, etc. and look for Drivers. Update ALL new drivers at the same time and install them accordingly.
Jan 24, 2014 | Samsung Realtek HD Audio
Dell dimension wont boot up to windows..
System restore:
To use System Restore to restore Windows XP to a previous state, follow these steps:
  • Log on to Windows as an administrator.
  • Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
  • On the Welcome to System Restore page, click to select the Restore my computer to an earlier time option, and then click Next.
  • On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
  • Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  • On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  • Log on to the computer as an Administrator. Then click OK on the System Restore Restoration Complete page.
If you successfully restored your computer to a previous state, and the computer performs as expected, you are finished.
Use asystem utility tool like RegInOut to fix corrupt registry and windows files.
For Restoring in Windows 7:
http://windows.microsoft.com/en-US/windows7/why-is-my-screen-black-when-i-start-windows-7
Hope it works for you.
Jan 04, 2012 | Dell Dimension 4600 PC Desktop
My IBM computer doesn't recognize when I plug in the usb camera patch cord and even the display goes blank on the camera. So do I need a new driver or camera
Welcome to Fixya
Did you accidentally dropped the camera? You should be able to see options when you plug in the camera to your computer. Try to reset the camera first to factory state as part of our initial troubleshooting.See procedure below:
Select reset settings icon Press set button Reset setting screen should appear then press YES Press the SET button Camera setting should be reset then test the issue again
Thank you for using Fixya!
Jun 10, 2011 | Sanyo VPC-C5 Digital Camera
I have samsung g 19000 and i have forgot my unlock
hi,
if you forget your lock code try to reset your phone in ths easy way...but i want you to know that all of your data will be deleted...
here is the instruction...
1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and
reinsert it
2. Hold the Volume Down button
3. Press and release the Power button
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage,
and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If the above procedures doesn't work, use this second method below,
1. Shut Down Samsung I9000 Galaxy S
2. Now press the Volume up, Home and Power button together.
3. When Samsung Symbol shows up release the power.
4. Then there is a boot Menu. Use the volume up/down to choose and home to select.
If YES is selected, all data including third-party applications will be deleted from your
Samsung I9000 Galaxy S. Once the wipe is complete, the phone will reboot to its factory
fresh state.
Apr 14, 2011 | Cell Phones
Did a system restore from previous restore point and now my computer doesn't recognize the drive. Don't have the startup cd so can't re-install it. Need the driver but the one on HP website doesn't...
Do you get an error message stating that USB device is not recognized? And is the yellow LED on the front flashing one and off rapidly? If yes, it is likely not the driver. It could be that your HP Personal Media Drive has "bricked". There is a firmware issue with some drives that causes it to lock up and it won't be recognized. It is possible to restore the drive (with no data loss) by using some hacker methods which are described on the internet in a lot of detail. Once the drive has been unbricked, you need to upgrade the firmware to prevent the problem from happening again. I successfully performed the fix using information found by searching "unbrick seagate drive". Good luck.
Aug 18, 2010 | HP HD5000S 500 GB USB Hard Drive
Gateway computer - cannot boot up--
At boot up press F2 and enter BIOS. Here check if your HDD is recognized. If yes Ten your Windows is corrupted and needs to be reinstalled. How to install and save your data follow the link below:
Crashed Windows : No Problem
If the HDD is not being recognized then run Auto Detect to recognize the HDD. If it works fine, if not then the HDD may need a change.
Jan 25, 2010 | Computers & Internet
Windows doesn's recognize camera, device manager says no driver
Hi -
Have you tried another USB port? Sometimes, they can act goofy.
Also be sure your anti-virus isn't blocking any part of the installation.
Here is a link to the Samsung troubleshooting guide for your camera.
You can probably download the most recent driver from that website as well.
Perhaps they have a better or newer version than what came prepackaged
with the camera (just because a camera is a new purchase does not mean
the software it came with is the most updated).
http://tinyurl.com/5zsvwd
I run WinXP home edition, so I am not familiar if there are any differences in the professional version regarding software installation....
Dec 17, 2008 | Samsung L100 Digital Camera
Samsung SHW08A DVD±RW doesn't burn dvd+r
Its because you need a firmware update. The media you are currently using isn't recognized. I stumbled in here with the same problem. I haven't been able to find an update, so I will probably have to try a different brand of disc myself. The burner worked fine until I tried using a new pack of Verbatim discs.
May 21, 2008 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
