Question about Honeywell Heating & Cooling
Have an approx 20 year old Honeywell ducted air conditioning unit in my just purchased villa. It is not working. Am having trouble finding someone to quote to repair it. I live in the southern suburbs of Sydney. Any suggestions? Thank You! Linda
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
If its 20 years old it would benefit you much more to replace it, see the energy star website and it has information on when replacement is the best solution. Over 10 is the general rule of thumb if it over 10 then replacing the equipment will benefit you so much more than a repair. Also honeywell doesn't make equipment anymore and i cant say vie seen one but that doesn't mean its not out there, vie seen Chrysler air conditioners in houses and honeywell dose make controls but not equipment anymore (in fact this is the first honeywell unit vie heard of).
Posted on Oct 01, 2010
Testimonial: "Thanks very much I thought it might be too old!"
Wall air conditioning unit is dripping water into my condo
I have a 20 year old one that drips after a while on a hot day. I put a small bowl to collect it. It could be old or the ac unit ins't tilted enough to go outside.
Sep 07, 2012 | Kenmore Heating & Cooling
I have a honeywell furnace about 14 years old. The igniter just stopped working. Where do I find a igniter?
Hello, you can purchase a igniter at any heating and cooling store. they usually range between 20= 30 dollars.
Feb 03, 2011 | Honeywell Heating & Cooling
Air condition jsut 10 month old ... not keeping up whith cooling
If it's only 92° outside and the unit won't cool the house, then the unit is either to small or it's low on refrigerant. They are designed to cool a house with outdoor temperatures up to 115° to 120°.Usually you need one ton a/c for every 400 square feet of house, but, you have to take into account for average outdoor temperature and humidity, windows, doors, especially sliding glass or patio doors and which side of the house they are on, insulation in walls and attic.
The air leaving your duct work going into the rooms should be about 20° lower than the room temperature, if you have a 80° room then the air leaving the duct should be around 60°. if it is then the unit is probably to small if, everything is working properly.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Short cycling air conditioner
depending onthe age of the unit it would be wise to have someone use a refrigerant leak detector to find the source of the problem. if it is over 15 years old i would probalby think about replacing the unit with a new 410A refrigerant unit due to the R-22 refrigerant getting phased out of production(the price is really going up) it sounds like the company you have might not know what they are doing i would look in the phone book and call another company and ask about doing a whole sytem leak search it might cost about $500 bucks to find the actual leak and repair it (have the guy physically show you where it is with his meter) but its a lot cheaper than adding refrigerant every year
Jun 27, 2009 | Heating & Cooling
Heater air conditioner unit does not expel air
unless you have zones installed i.e. day and night you will probably find that the main duct off the unit has fallen off
Jun 15, 2009 | Heating & Cooling
Vacuum works perfectly, I just want any/all information I can get on unit. I know unit to be over 20 years old, but in new condition. (no books)
the vacuum is about 20 years old. i have the same one. i got it when i got married 20 years ago. mine still works except i somehow lost the part that goes on after you put the belt on. Does yours have a black rubber ring at the end of the belt?
Jun 02, 2009 | Royal Vacuums
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
Our air conditioning was working during the day. when one family member turned the air up from 72 to 75 she saw the screen process what she wanted and walked away. when another family member went to turn...
open the thermostat and look for batteries, 3 AA
http://www.heater-home.com/photos/2129-5b.jpg
http://www.heater-home.com/manuals/th8321u1006manual.pdf
Jun 13, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
115 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
